First post, by DosFreak
- l33t++
MAIN SYSTEM
Case: SAMA IM01 $69.99 (Currently inverted)
Case feet: 4x Monosaudio 40x20mm Speaker Isolation Feet Speaker $15.50
PSU: CORSAIR SF1000 (2024) SFX
Motherboard: ASUS TUF Gaming B850M-PLUS WiFi AMD AM5 B850 mATX $240.89
Processor: AMD Ryzen 9 9950X3D 16-Core Processor$974.55
Processor cooler: Noctua NH-U12A $119.95
Memory: 1x G.SKILL Trident Z5 Neo Series AMD EXPO 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6000 (PC5 48000) $259.99
SSD: 2x SK hynix Platinum P41 2TB PCIe NVMe Gen4 M.2 $644.46
Fans:
REAR EXHAUST 1x Noctua NF-A9 PWM chromax.Black.swap, Premium Quiet Fan, 4-Pin (92mm, Black) $19.90
CPU TOWARDS EXHAUST 2x Noctua NF-A12x25 PWM chromax.black.swap, Premium Quiet Fan, 4-Pin (120mm, Black) $65.80
BOTTOM INTAKE 2x Noctua NF-A12x25 PWM chromax.black.swap, Premium Quiet Fan, 4-Pin (120mm, Black) $65.80
Video card: GeForce RTX 5080 PNY Slim Dual-Fan, Dual-Slot OC 16GB
Monitor: LG 38GN95B 37.5" 3840x1600 144hz OC 160hz
OS: Proxmox w/Fedora Aurora and Windows 11 guests
LAPTOP
Framework Laptop 13.5" w/ AMD Ryzen AI 300
Chipset: Ryzen AI 9 HX 370 w/Radeon 890M
Memory: Kingston FURY Impact 64GB 2x32GB 5600 MT/s
SSD: Samsung 990 PRO 4TB M.2 2280
WIFI: Intel Wi-Fi 6E AX210
EGPU Geforce RTX 4080
EGPU: GPU: Geforce RTX 4080 16GB VENTUS 3X OC $1157.00
Adapter Cable 80cm Compatible with Thunderbolt 4 * 1
Adapter: JMT ADT-UT3G USB4.0 Docking Station 64G PCIe4.0x4 to Laptop Graphics Card External Conversion Adapter Compatible with Thunderbolt 3 4
Case: Fractal Design Ridge Black - PCIe 4.0 Riser Card Included - 2X 140mm PWM Aspect Fans Included - Type C USB - m-ITX
PSU: SilverStone SX1000 1000W SFX-L
LAPTOP
Dell XPS 15 7590
WIFI: Intel AX210
SSD Samsung PM9A1
AUDIO
Logitech Z-5500 505 Watts 5.1 Digital Speaker System
KVM
IOGEAR GCS1944 Displayport KVM 4 port
MICE
1x Razer Deathaddder Elite
1x Razer Deathaddder Esential
KEYBOARD
CORSAIR K95 RGB PLATINUM Mechanical Gaming Keyboard
Logitech K740 Illuminated USB Keyboard
CARD Readers
2x SCM SCR3310
NETWORK
Netgate SG-1100 Firewall
Cisco SMB SG350XG-2F10-K9 12 Port Stackable Managed 10 Gb Ethernet Switch
Arris Surfboard SB200 Cable Modem
Asus AC1900 802.11ac Gigabit
Backup Intenet using Cell Phone
2x Asus AC1900 802.11ac Gigabit
BACKUP
1x QNAP TVS-672 6 Bay 6x16TB w/ QNAP QXG-10G1T Single-Port (10Gbase-T) 10GbE w/ QNAP QM2-2P-384 M.2
1x QNAP TVS-670 6 Bay 6x20TB w/ Asustor AS-T10G3, 10GbE & M.2 NVMe SSD Network Card
1x Synology DS1512+ 5x16TB 1GBE
1x Synology DS211+ 2x12TB 1GBE
1x Synology DS713+ 2x12TB 1GBE
PROXMOX TEST 2000/XP/Vista/7/8/10/11/Linux
CPU: Ryzen 9 5950x
CPU Cooler: Corsair iCUE H150i w/ 3x Noctua NF-A12x25 PWM chromax
Motherboard: MSI Meg X570 Unify
NIC: Intel Ethernet Converged Network Adapter X550-T2 (10GB)
Memory: G.Skill 32GB DDR4 PC4-28800 3600MHz Ripjaws V for Intel CL16 (16-19-19-39) Dual Channel kit (2x16GB)
GPU: 8800GT 512MB (2000 Vanilla)
EGPU: Zotac Geforce GTX 980 Ti 6GB AMP! Extreme GDDR5 ZT-90507-10B PCIe (Windows XP,Vista)
EGPU: ASUS Dual NVIDIA GeForce RTX 3060 V2 OC Edition 12GB GDDR6 Gaming Graphics Card (7+)
Video card: EGPV-1101-C1 M.2 (Proxmox Console)
Audio: Realtek® ALC1220 (Vista+)
Audio: Creative Sound Blaster Audigy PCIe RX 7.1 (2000/XP)
Monitor 1: Acer XB271HU 27" 2560x1440 "Acer Predator XB1"
DVD: Blu-ray LG WH16NS60
SSD: Seagate FireCuda 530 1TB
SSD: Seagate FireCuda 530 4TB
PSU: CORSAIR RMx Series, RM1000x, 1000 Watt, 80+ Gold Certified, Fully Modular Power Supply
Case: Corsair 600C Black ATX Full Tower Computer Case w/ 3x Noctua NF-A14 PWM chromax
PCIe 4.0 x4 to Oculink External SFF-8612 Adapter Card for eGPU Dock Mimi Pc
EGPU 980TI
Cable: ONE XPLAYER OCuLink Cable for OneXGPU eGPU, SFF8611, 3.3ft Long, PCIe 4.0 x4
PSU: Corsair SF Series, SF750, 750 Watt, SFX, 80+ Platinum Certified, Fully Modular Power Supply (CP-9020186-NA)
Occulink card: PCIe x4 Gen4 with ReDriver to OCulink 4i Host Bus Adapter
EGPU 3080
GIGABYTE Gaming OC GeForce RTX 3080 10GB GDDR6X PCI Express 4.0 ATX Video Card GV-N3080GAMING OC-10GD (rev. 2.0) (7+)
Case: Fractal Design Ridge Whote - PCIe 4.0 Riser Card Included - 2X 140mm PWM Aspect Fans Included - Type C USB - m-ITX
PROXMOX Test DOS\9x (VESA)/NT4 (VESA)/2000 (XP+ Backup)
Processor: Intel Core i7 6700k
CPU Cooler: Noctua NH-U9S w/2 Noctua A9 92mm fans
Motherboard: ASUS PRIME Z270-A
Memory: Patriot Viper 4 32GB (4 x 8GB)
NIC: Intel X540-T1 10GB
SSD: Seagate Firecuda 530 1TB (Proxmox)
SSD: Seagate Firecuda 530 2TB (Proxmox VMs)
PSU: Corsair RM850x
Audio: Creative Sound Blaster Audigy PCIe RX 7.1 (9x/2000/XP)
Monitor: Dell Ultrasharp U2410F 24" 1920x1200
GPU : Geforce GTX 780 (2000 BWC/XP+)
GPU: Geforce FX 5200 128mb (9x-NT) (2k-xp for games that need it)
Case: CoolerMaster ATC-110 w/ 4x Noctua NF-A8 PWM fans
Amebay 5.25 Inch Front Panel USB Hub 2port 3.0, USB 2.0 for Computer Case
DVD: Blu-ray LG UH12LS28
SERVER
CASE: SUPERMICRO CSE-743T-650B Black 4U Case 11 Bays (Replaced case fans with Noctua Fans)
CASE ADDON: Supermicro CSE-M35TQB 5-in-3 Hot Swap SAS/SATA Mobile Rack (Black)
PSU: Supermicro 1200w ATX12V Power Supply - 1 kW, 1.20 kW - Internal - 110 V AC, 220 V AC (PWS-1K25P-PQ)
MOTHERBOARD: SUPERMICRO MBDH11SSL-I Rev 1.01
PROCESSOR: AMD EPYC 7351P 16-Core
PROCESSOR COOLER: ARCTIC Freezer 4U for AMD SP3
MEMORY: 4x Supermicro Certified MEM-DR432L-SL03-ER26 32GB DDR4-2666 LP ECC REG DIMM
ADDON CARD: ASUS Hyper M.2 x16 PCIe 3.0 x4 Expansion Card V2
ADDON CARD: NFHK Dual 2X NVME M.2 AHCI to PCIE Express 3.0 Gen3 X8 X16 Raid Card VROC Raid0 Hyper Adapter
NIC: Intel Ethernet Converged Network Adapter X540-T1 10GBE
HARD DRIVE: 13x Seagate IronWolf Pro 22TB NAS (ST22000NT001) (DATA)
ADDON CARD: 2x Sabrent Rocket Q 8TB M.2 for ASUS Hyper M.2 x16 (1x ESX VM OS and 1x VM DATA)
ADDON CARD: 4x Seagate FireCuda 530 1TB Solid State Drive - M.2 PCIe Gen4 ×4 NVMe 1.4 (DEDUPE)
ONBOARD M.2: 1x Samsung SSD 970 EVO 2TB - NVMe PCIe M.2 2280 SSD (MZ-V7E2T0BW) for onboard M.2 (Vmware ESX)
LSI 9305-24i x8 lane, PCIe 3.0 Full Height SAS SAS 9305 12 Gb/s SAS Host Bus Adapter
Dual Fan bracket w/ Noctua NF-A12x25 PWM for LSI 9305 (Brought temp down 17c)
Living Room
Projector: Optoma UHD60 4K
Console:Nvidia Shield TV Pro
Keyboard: Logitech K800
Mouse: Corsair Harpoon RGB Wireless
Audio: Sonos Beam, Sonos Sub
CURRENTLY UNUSED
GPU: ASUS Dual NVIDIA GeForce RTX 3060 V2 OC Edition 12GB GDDR6 (Windows 7+)
EGPU: SAPPHIRE NITRO Radeon RX 7900 XTX 24GB GDDR6 PCI Express 4.0 x16 ATX Video Card 11322-01-40G (Windows 10/Linux+)
Audio: Sound Blaster X-Fi Titanium (XP)
