First post, by mpe
I had the idea for some time and only decided to do it now when I am locked at home.
I wanted to put my Gravis Ultrasound mini collection on display in my house. GUS cards could be a bit troublesome for retro use, but the red PCB make them visually attractive. They make a nice interior design feature in my opinion.
So I took a 20"x20" frame and glued them onto the frame (using a blue tack if I ever decide to use them again):
1.41 MiB
1 MiB
As there is only limited surface area I was thinking about the layout.
Instead of late model MAX, shall I use the original full-length GUS MAX 1.8 instead (which I also have albeit in a bit dusty condition).
Should I make it more dense and reserve a space for GUS Extreme (if I ever come across one) to display a complete family?
Would you put some labels above cards?
Would you remove factory stickers or memory upgrades to give them cleaner look?
Blog|NexGen 586|S4
Reply 2 of 9, by matze79
where is it on show ? public ?
Reply 4 of 9, by mpe
OK. Cleaned the other card and swapped MAX 2.1 for MAX 1.8. Looks cooler with longer PCB and socketed chips. Will keep the MAX 2.1 for my retro PCs...
Ready to go above my working desk. Will still think about labels.
1.22 MiB
Blog|NexGen 586|S4
Reply 7 of 9, by Predator99
Indeed. And then talking about removing the labels...thats a sacrilege. Think the meaning of the thread is to show us all the cards he own.
I think I have more than you and I will never remove the labels or put them on the wall to be bleached out by the sun...
Reply 8 of 9, by mpe
OK, thinking about removing factory stickers from those wasn’t a great idea. However, I often remove damaged, non-factory stickers, retailer/OEM bar codes, OEM warranty void labels, etc. On the other hand a handful of times I even restored damaged factory stickers (as it is not a good idea to keep EPROM chips without one).
However, what to do with retro gear once collected is a dilemma that every collector must solve I think. Keep them in a storage forever? Build a number of retro-PCs and keep using them? Start a museum?
I actually like the idea of putting interesting pieces on display in my house. Make a great conversation point and let me enjoy them more that if they were stored in my attic. There should be no sun damage as those frames are designed for paintings and have UV blocking glass.
Predator99 wrote on 2020-04-04, 07:14:
You ain't seen nothing yet 😀
Blog|NexGen 586|S4
Reply 9 of 9, by imi
I don't have a single one and I still appreciate it :p... I'd also say it's nicer to have them on display than stored away somewhere, and if you still have one to use even better 😀
