Reply 20 of 141, by traffkin
seems to be working as expected! fantastic 😀 i'm super thankful
btw, i might found a bug... in some circumstances applying ping-pong loop to the sample causes the ft2 to crash, couldn't repeat it though...
traffkin wrote on 2020-03-26, 23:48:thanks a lot! will test it tonight 😀
8bitbubsy wrote on 2020-03-26, 14:27:https://www.dropbox.com/s/ozdpo0oxtz0u3ua/FT2 … DI_PRG.ZIP?dl=1 15:41 EDIT: I did a mistake in the code, I fixed it now. […]
15:41 EDIT: I did a mistake in the code, I fixed it now.Let me know if it works, I don't really know what I'm doing since I don't know MIDI stuff very well.
As said before, this will permanently disable the program change on MIDI out, so it's possible that it messes something up by never sending that data.
