Install Toonstruck
First post, by moril
Hi! I`m new to to DOSbox and I can`t find the **** ":" button. when I press it, I only get this ">". So when I`m gonna write F:\INSTALL it stands like this F>\INSTALL. I`ve searched every single button. I think I`m going MAD 😵. So pleas help me!_____________Thanks___________
Reply 1 of 8, by eL_PuSHeR
Keep trying.
Or use the keymapper (CTRL-F1)
Or install FreeDos Keyb.com
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 8, by moril
When I try remapping the keys (ctrl+F1) my DVDplayer comes up (InterVideo WinDVD 5). And where can I find FreeDos Keyb.com?
Reply 3 of 8, by wd
Rank DOSBox Author
DOSBox Author
I guess you can't use the DVD player to remap the keys.
keyb.com should be easy to find via google, otherwise try the
freedos homepage as a starting point. Btw. the dosbox readme
has a link to it.
Reply 4 of 8, by moril
I found out that : = alt-58. But I get an error when I try to install it on C: or D:
the error = Drive C: [or D:] does not exist or is not writeable. 😖
Reply 5 of 8, by eL_PuSHeR
How did you mounted it?
Intel i7 5960X
8 GB DDR4 (2100)
Reply 6 of 8, by moril
I`ve don it!! But its realy slow 🙁 , so how can you get it faster?
Reply 7 of 8, by moril
I made it work faster. I don`t think I need more help now. Thank you all
Reply 8 of 8, by eL_PuSHeR
Glad to see someone self-sufficient for a change... 😎
Intel i7 5960X
8 GB DDR4 (2100)
