post up pics of your "computing area"
Reply 1460 of 2368, by DaveJustDave
cleaned things up a bit
I have no clue what I'm doing! If you want to watch me fumble through all my retro projects, you can watch here: https://www.youtube.com/user/MrDavejustdave
Reply 1461 of 2368, by pete8475
Fujoshi-hime wrote on 2020-03-09, 01:52:
...Oh hell, I accidentally built a YouTube set... (Probably doesn't help that I had mock graphics ready for such an event) http […]
Great setup!
Be careful with cords around that rad though, they can get very hot if you're using the heat!
Reply 1462 of 2368, by JoeCorrado
My work (FUN) space is of course, in the basement. The only place that I can spread out and not be in my wife's way! It has taken a long while to make it to this spot, and there is still plenty to do. It is my retirement plan since everybody tells me that when you retire, we all need a hobby. This is mine.
The first shows the workbench. Currently, a 486DX4/100 WFWG build on a LuckyStar 486 motherboard.
The second is my "play space" - Three PC's running DOS through WIN98se capable machines.
The third shows inventory and storage space. (I get carried away sometimes- but am ready for most projects!)
Retirement- is that a light I see up ahead??
The attachment 2020-03-24 07.33.33.jpg is no longer available
The attachment 2020-03-24 07.34.38.jpg is no longer available
The attachment 2020-03-24 07.34.15.jpg is no longer available
-- Regards, Joe
Expect out of life, that which you put into it.
Reply 1463 of 2368, by Fujoshi-hime
pete8475 wrote on 2020-03-26, 03:48:
Great setup!
It's not a problem, I don't use that radiator and if I do, since I'll use that area more, I'll keep it low. If you look at the bottom it has a valve, so I can shut it off entirely or run it at a trickle so it just gest 'warm'. 😀
Reply 1464 of 2368, by chinny22
DaveJustDave wrote on 2020-03-25, 19:00:
very nice and organised but must hurt messing round on the mac's after a while 😉
Reply 1465 of 2368, by ynari
I'm finally not ashamed to show the setup of my study/computing room. With the UK in lock down and spending more time in this room than any other due to home working, I figured I'd better get the room ship shape.
Bar a couple of unfinished builds, a coat of paint, and tidily wiring everything the room is not far off what I want it to be. There are going to be fourteen computers (and a Raspberry Pi) in here once it's complete. Most are either under the desk, or behind/to the side of the monitors.
It's quite a small room, so fitting everything in is a little challenging.
Reply 1466 of 2368, by chinny22
Working from home has inspired me to setup my area. Will most likely be moving start of next year so only temporarily and while far from ideal happy with the finished result.
I went with how many PC's can I get into the space my Mrs has allowed
Bottom row left to right.
Duel PPro NT3.51, P4 Win98, Socket 775 XP, Duel HP xw6200 SBS2k, Duel Dell Precision 650 NT4, Duel Prolient 1600
Top row left to right
Duel Slot1 Win2k, Dell T500 Win98, Mac OS9 & 10, Bottom desktop Dx2/66 Win3.11, Top desktop POD83 Win95
Under the desk
SlotA 650 Win98, P3 Laptop as part of my SBS2k build, Hardmod OG xbox with 2TB HDD.
The left screen is attached to one of the 4 port KVM's underneath.
The CRT is attached to the other 4 port KVM
The Middle screen is attached to the 8 port KVM underneath.
Currently only the xbox is hooked upto the Logitech T5500 5.1 speakers, I have an optic splitter to connect some of the PC's but on the rare times I fire up a game I'm using headphones at the moment so no rush.
Desk is in work mode with boring Win10 laptop hooked upto the 8 port KVM, Have been known to play simcity classic on the DX4 in the background on quieter days though 😉
Reply 1467 of 2368, by JoeCorrado
chinny22 wrote on 2020-03-31, 10:04:
... happy with the finished result.
Nice. It looks like a comfy spot to spend some time just relaxing and enjoying.
-- Regards, Joe
Reply 1468 of 2368, by JoeCorrado
Good Lord! It is a showcase! A great job and thanks for saving so much of the PC history!
-- Regards, Joe
Reply 1469 of 2368, by JoeCorrado
Salient wrote on 2020-03-18, 18:33:
Latest iteration of my desk.
Now that is what I am talking about! I am loving the separation between more modern and retro there!
-- Regards, Joe
Reply 1471 of 2368, by pewpewpew
With so many of us on the Inside, I imagine we could do a pretty good sub-thread just of the piles that have formed as we re-arrange our space.
Reply 1472 of 2368, by kolderman
I like those twin beige boxes. What have they got in them?
Reply 1473 of 2368, by pewpewpew
kolderman wrote on 2020-04-04, 00:29:
A mausoleum of my final P1 & PPro, with all the spare drives & cards that would fit, to accompany them into what the afterlife may hold.
Reply 1474 of 2368, by Lylat1an
My four main PCs, from left to right:
My modern gaming beast
A backup server.
My Retro Rig.
And a laptop for looking up guides when I get stuck in games.
(The second server tower is empty, together they hold up that shelf)
I also have a small convertable laptop for displaying my modern PC's system loads, but I lent it to a friend for the time being.
Reply 1475 of 2368, by imi
that's a nice way to hold up a shelf x3
Reply 1476 of 2368, by gdjacobs
Lylat1an wrote on 2020-04-04, 22:07:
https://img.photobucket.com/albums/v602/FIRE-FLARE/IMG_20200404_140105187_zpsifiksb7f.jpg […]
A backup server.
My Retro Rig.
That case with the slot load drive is interesting! What is it and what's it loaded with?
Reply 1477 of 2368, by bjwil1991
gdjacobs wrote on 2020-04-05, 18:32:
According to: Re: Retro Rig Photo Thread
Really interesting to see that.
Reply 1478 of 2368, by Lylat1an
It's not a computer, it's a 4-bay SCSI drive enclosure that I repurposed to let the IBM case beside it appear stock.
The enclosure now has an AT power supply inside it along with extension cables so the drives and power connectors can reach the motherboard in the IBM case.
Together they're my Retro Rig, which has DOS 6.22 and Windows 98SE on separate removable drives.
Reply 1479 of 2368, by bjwil1991
Dude, I cannot tell you how freaking amazing that is. That's the sweetest setup I've seen all my life.
