appiah4 wrote:...
Less success with Indy 4 and Space Quest 3 - wrong instruments in many parts. I will give this another try in a real PC sometime, though. Maybe SOFTMPU /MT32 will give me better results than the BAT files. Regardless, it's not a straightforward or reliable method from what I've experienced so far, so I will continue to use a raspberry for MUNT in series with the X3M.
There is no chance that using SOFTMPU /MT32 gives you better results. Instead you should test with games that do not use custom instruments. Space Quest 3 is definitely not one of them.
Here's a list of games that you could try:
Leisure Suit Larry 2,
Legend of Kyrandia 1 (except for one instrument),
King's Quest IV,
Budokan, Ultima VI,
Bad Blood,
Simon the Sorcerer,
Loom,
Monkey Island 1,
Dune,
KGB/Conspiracy,
Spellcasting 101: Sorcerers Get All The Girls,
Spellcasting 201: The Sorcerer's Appliance,
Timequest,
Gateway,
Spellcasting 301: Spring Break,
Eric the Unready,
Gateway 2 - Homeworld,
Companions of Xanth,
Death Gate,
Superhero League of Hoboken
