First post, by ninja mariachi
Howdy. This is probably a remarkably simple question, but I looked at the guides and used the search a bit and I had no luck at all.
I've got DOSBox 0.65 for Mac OS X on my machine, and I'm trying to run either or both of the games in the title. I figured out how to mount disks just fine and I can get to the directory I've got the .exe files in, but when I actually type the name of the program as shown by "dir" to run it, it says:
"This program cannot be run in DOS mode."
However, both games say they're supported on the main DOS Box website. What's up?
Reply 2 of 6, by Xian97
Usually you only see that message when it is a Windows executable file that you are trying to run in DOS. The Neuromancer game I remember was released in 1988 by Interplay, years before there were any Windows games. The executable file was Neuro.exe.
Reply 3 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
probably a selfextracting archive.
try unzipping/unrarring it manually
Water flows down the stream
Reply 4 of 6, by HunterZ
I'd have to agree with Qbix. Neuromancer is old, so it's probably a self-extracting archive. Try opening it in an unzip program and see if it recognizes it.
Reply 5 of 6, by appas
Hey,
so I'm having some problems running Circuit's Edge, as well. When I start EDGE.EXE I get a screen saying it'll run with VGA/MCGA graphics, a Microsoft Mouse, hard drive, one 3.5" floppy (A) and Roland MT-32 for audio. When I select 1, for "Use these settings", I get a black screen and no progress.
What gives? The game is listed as "supported" on the DOSBox website.
Reply 6 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
1. please do not necro post (don't post in threads that are years old, the last post had been years ago, other thsb the thread title your problem is different)
2. please try reinstalling from your original media the game came from, following the 60 seconds guide.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
