Reply 240 of 958, by feipoa
- l33t++
I have tested the latest DOS revision for HWiNFO. I have had to create a custom boot diskette to load DOS and just HIMEM because some features of HWiNFO offer misleading information if EMM386 is loaded.
This is now shown:
CPU Stepping: 0, 5 Rev
I'd personally write it out: Step 0, Rev 5 so that people don't think "0, 5 Rev" is a 0.5 revision of the stepping.
Note that 0 , 5 Rev doesn't even show if using EMM386.
Under CPU Codename: M0.9/M1sc. What is the M0.9? An abandoned Cyrix codename?
HWiNFO now shows the IRQ's that are consumed, and for the most part, still shows the proper IRQ's if EMM386 is loaded, except that IRQ 9 doesn't show the Ethernet card, just shows "rerouted from IRQ 2" if EMM386 loaded
Its nice that HWiNFO can read the amount of RAM installed on the Creative AWE64 cards. I should try it with 28 MB to see if it can still read it.
It would be nice for ISA PnP cards to also show up under the ISA bus heading.
I'm curious, what criteria are used to determine if the motherboard has PCI revision 2.00 or 2.10?
I also found it interesting that HWiNFO is able to determine the made and model of my LCD monitor, as well as the manufacturing date. Pretty advanced for a DOS program.
