First post, by jheronimus
Hi!
Today I got this card, an Iwill SIDE ver 1.31 controller for SCSI and IDE.
It's a pretty cool VLB controller, but unfortunately the BIOS chip has been removed. I'd like to make a replacement, so I would wondering if anyone could make a BIOS dump.
MR BIOS catalog
Unicore catalog
Reply 3 of 25, by luckybob
Widen your search.
find the bios file for the Adaptec chip and program that to the card. My instincts tell me the IDE and serial/parallel/floppy don't need bios help. SCSI will 100%. Looking at Adaptec cards on google. the 1532A scsi card has the same scsi/floppy combination and scsi controller chip the AIC-6360Q
I dont have a 1532 handy, but I'd program its bios to a spare flash chip and give it a shot. I say the 1532A, because it is PnP. The card you pictured doesnt have the massive jumper blocks that earlier cards have (i.e. 1522)
Reply 4 of 25, by jheronimus
luckybob wrote on 2020-04-19, 00:06:
My instincts tell me the IDE and serial/parallel/floppy don't need bios help. SCSI will 100%. Looking at Adaptec cards on google. the 1522A scsi card has the same scsi/floppy combination and scsi controller chip the AIC-6360Q
The BIOS actually gives a menu to configure the entire board, including IDE and resources for COM/LPT/Gameport. Even the non-SCSI SIDE board had a BIOS.
Also, the board doesn't even have any jumpers for IDE or other devices — they are only used to allocate resources for BIOS.
So I don't think a SCSI BIOS will cut it here.
MR BIOS catalog
Unicore catalog
Reply 5 of 25, by luckybob
NO.
Those settings you speak of are in the motherboard bios. I have countless ISA IDE/serial/floppy/parallel cards and none of them even have a bios connection.
I'd alos source the bios file for the adaptec AVA-2825 as well. I bet one or the other will work fine.
Reply 6 of 25, by jheronimus
luckybob wrote on 2020-04-19, 00:24:
Here's a page from the manual to Side Jr (the non-SCSI version)
It specifically states there's a separate BIOS utility. And it really doesn't look like Award/AMIBIOS.
Upd: also tried booting from the card: only the floppy works right now.
MR BIOS catalog
Unicore catalog
Reply 8 of 25, by luckybob
darry wrote on 2020-04-19, 01:19:
Going by a different thread (IWILL SIDE VLB IDE/SCSI/IO controller setup?) , cyclone3d seems to have one , maybe you can PM him .
well, that's the best solution after all.
Reply 9 of 25, by Horun
The aic-6360 Adaptec chip can work without a BIOS but only if there are jumpers to set the IRQ, Port, etc. I attached the AIC-6360 util to check it's settings from within DOS, you might want to see if it recog's the scsi part.
    152xbcfg.rar
    101.04 KiB
    54 downloads
Reply 10 of 25, by jheronimus
Huh. Tried disabling the BIOS via the jumpers, and the controller actually works now. I've been able to detect an IDE HDD and boot from it. The serial mouse gets detected by ctmouse but doesn't work, though.
PM'd cyclone3d, hope he has an EPROM reader 😀
MR BIOS catalog
Unicore catalog
Reply 11 of 25, by darry
jheronimus wrote on 2020-04-19, 01:58:
If he doesn't have a reader, it imagine it should be possible to dump it through software running on a PC . It is an option ROM, after all, isn't it ?
Reply 12 of 25, by cyclone3d
Yep, I have one. Was already looking at this thread before the PM.
I'll have to pull out my reader and hook it up as I've never actually used it. I'll try to get the image pulled later this evening.
I will say that the computer I was initially trying to use the SIDE with didn't play well with it. It made me angry so I pulled it out and installed a regular VLB controller which works great with that setup.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 13 of 25, by jheronimus
cyclone3d wrote on 2020-04-19, 02:08:
Thanks, really looking forward to it. Well the controller works okay now with IDE and floppy, but I can’t set the IRQ for other ports.
MR BIOS catalog
Unicore catalog
Reply 14 of 25, by Unknown_K
You know I could have sworn I have this card, but after looking through some boxes for 20 minutes all I came up with was the Always AL-7000 and a Control Concepts something or other IDE/SCSI/IO VLB cards.
Reply 15 of 25, by cyclone3d
Not 100% sure that this BIOS will work with your card as yours is a 1.31 and mine is a 1.4. The layout is a bit different and the one chip is SMC instead of UMC.
The EPROM is a ST M27C256B
The zip file contains the .BIN file and a text file with the EPROM specs.
IWILL-SIDE_JTHQUICKSIDE_1.4B.zip
18.49 KiB
66 downloads
GPL-2.0-or-later
.BIN was saved from my apparently counterfeit MiniPRO TL866A - or at least that is what it tells me when I run the updated software from them after I upgraded the firmware on it.
YMF7x4 Guide
Reply 16 of 25, by jheronimus
cyclone3d wrote on 2020-04-19, 05:27:
Not 100% sure that this BIOS will work with your card as yours is a 1.31 and mine is a 1.4. The layout is a bit different and th […]
Wow, thanks a lot!
Turned out, the chip I wanted to use as a replacement is not rewriteable, so I'll have to source some chips to test the ROM — don't want to kill working hardware for the test.
MR BIOS catalog
Unicore catalog
Reply 17 of 25, by Cizetta
Hello,
I know this is an almost two years old thread but recently I got such IO card and its BIOS seems to be working so I can dump it if it is still needed.
Reply 18 of 25, by darry
Cizetta wrote on 2022-03-18, 17:56:
Hello,
If it is not too much trouble for you, please do dump it as while it may no be needed currently, someone is likely to end up needing it sometime down the road .
EDIT : P.S. Welcome to Vogons !
