Unknown Coppermine CPU
First post, by computerguy08
Just found this in my untested hardware pile yesterday, no covers or heatsink. Tested it with a Katmai heatsink, it works, and reports as P3 550E @100FSB (my board can't do 133). Is there a way to find the S Spec on this one somehow ?
Photos
Reply 1 of 21, by The Serpent Rider
CPU-Z
Reply 2 of 21, by imi
doesn't it say on the plastic shell?
you can also check cpu-z for stepping.
Reply 3 of 21, by computerguy08
I got it a while ago without a plastic shell (the one in the photo is from a Katmai).
CPU-Z reports Model 8 Stepping 1 (rev cA2)
Reply 4 of 21, by derSammler
imi wrote on 2020-04-18, 11:01:
As he wrote, it didn't come with one and he used another.
Reply 7 of 21, by computerguy08
Isn't it very similar to a 733 SKU (it will be 550 at 100FSB, same 5.5 multiplier) ?
I've checked cpuworld and the stepping is identical to the 550 one.
Also, mine runs at 1.65V, which rules out the high end SKUs.
Reply 8 of 21, by PARKE
That is typical for a stepping series. Like this:
sSPEC // step // CPUID // speed
SL3N6 // cA2 // 0681h // 533EB/133
SL3SX // cA2 // 0681h // 533EB/133
SL3N7 // cA2 // 0681h // 550E/100
SL3V5 // cA2 // 0681h // 550E/100
SL3H6 // cA2 // 0681h // 600E/100
SL3NA // cA2 // 0681h // 600E/100
SL3H7 // cA2 // 0681h // 600EB/133
SL3NB // cA2 // 0681h // 600EB/133
SL3KV // cA2 // 0681h // 650/100
SL3NR // cA2 // 0681h // 650/100
SL3KW // cA2 // 0681h // 667/133
SL3ND // cA2 // 0681h // 667/133
SL3S9 // cA2 // 0681h // 700/100
SL3SY // cA2 // 0681h // 700/100
SL3SB // cA2 // 0681h // 733/133
SL3SZ // cA2 // 0681h // 733/133
SL3V6 // cA2 // 0681h // 750/100
SL3V7 // cA2 // 0681h // 800/100
SL3Z6 // cA2 // 0681h // 800/100
SL3V8 // cA2 // 0681h // 800EB/133
SL3WA // cA2 // 0681h // 800EB/133
If you want to be sure you can run the Bootable Intel(R) Processor Frequency ID Utility -see attached
bfid_e25.exe
Reply 9 of 21, by pentiumspeed
What's high end coppermine runs at what voltage?
Cheers,
Great Northern aka Canada.
Reply 10 of 21, by PARKE
Not sure if I understand that question.
The building materials for a stepping series are fundamentally similar. The manufacturers, like Intel and AMD, test the raw products in order to find out how they perform. The best performers will be classified higher, the lesser performers will be classified lower. The voltages will be adjusted conform the demands. In some cases better performers will be classified lower for marketing reasons instead of for their mechanical performance. AMD K6 and K7 are known for this phenomen.
Say, you have, for example, a 600E fsb 100 cpu from the above list and you run it at 800Mhz/fsb 133 and it behaves normally with stock voltage then you have a cpu that is for some reason marketed as a 600Mhz cpu but it is not fundamentally different from an 800Mhz cpu.
Another example... this 850Mhz/100 cpu runs at 1.133Mhz/133 without overvolting. The question is not if it is an 850Mhz -or- an 1.133Mhz cpu because it can do both. The branding that says that it is an 850Mhz cpu and that shows up in CPUZ is done for whatever reason that tickled the fancy of Intel at the time.
Reply 11 of 21, by computerguy08
PARKE wrote on 2020-04-18, 13:36:
If you want to be sure you can run the Bootable Intel(R) Processor Frequency ID Utility -see attachedbfid_e25.exe
I tried this and it says it expected a 733 MHz speed at 133MHz bus speed, whick makes it a SL3SB or SL3SZ. It worked, thank you.
Reply 12 of 21, by imi
great, but finding the specific s-spec isn't possible without the shell then?
Reply 13 of 21, by computerguy08
I tried googling the numbers on the actual die, no results.
Reply 15 of 21, by PC Hoarder Patrol
Would you get any hints by trying to read the QR code?
Reply 16 of 21, by jasa1063
Looking up PB 746509-001 online, it shows that it came out of a Dell PowerEdge 2450. It was a CPU card that plugged into the board.
Reply 17 of 21, by PARKE
PC Hoarder Patrol wrote on 2020-04-18, 21:15:
Sure, that code is located next to the sSpec number on the side of the plastic SECC cartridge and on the die in the first photo of this thread.
Reply 18 of 21, by Anonymous Coward
Even without the original shell, shouldn't the BGA chip still be marked? Maybe it's some kind of sample.
Reply 19 of 21, by imi
we'll know more after someone deciphers the QR code ^^
