OK. So I was going through the manual and I am wondering if the power supply is the issue.
Per the manual, they recommend 28 A on the 3.3v rail, 30.0 A on the 5v rail, 8.0 A on the +12v rail, 0.1 A on the -5v rail, 0.4 A on the -12v rail, 0.72 A on the +5v VSB rail.  The power output of the 3.3 and 5v rails should be 220w. Total power output should be 300w.
The first power supply I tried had 20 A on the 5v, 20A on the 3.3v rail for 120w total watts, 37.5A on the 12v rail, 0.3 A on the -12v rail, 3A on the 5vsb rail.  Total watts 450.
I then tried another older power supply that has more on the +5v rail.  It's ratings are 22A on the 3.3v rail, 45A on the 5v rail - total of 213w, 20A on the +12v rail, 0.8A on the -12v rail, 0.5A on the -5v rail and 2.0A on the 5vsb rail.
It looks like none of my power supplies have all of the recommended specs noted in the manual.
Is it possible that the power supply is the issue?  If so, does anyone know of a power supply that meets the requirements noted in the manual?
Thanks.
