Reply 14960 of 27502, by LewisRaz
brostenen wrote on 2020-04-27, 20:48:
Ahhh... Spaghetti lines... The monitor inerpret the signal incorrectly and tries to compensate. What you need, is eighter a CRT […]
LewisRaz wrote on 2020-04-27, 20:23:
Spent the last few evenings gaming on my 486sx50. Really enjoying this machine and seeing what it can do.
I have noticed this banding in certain resolutions with this vga card. The issue remains on the 3 systems I have tested it on.
Has anyone seen this before?
What you need, is eighter a CRT monitor or a GFX card with a better output.
These lines tends to show up, mostly on ISA and VLB vcards, however I have seen it with PCI as well.
Ah thankyou! The card is infact ISA!
I do have a CRT but this pc is merely an occasional interest so my "main" rig uses that 😀
My retro pc youtube channel
Twitter
Reply 14961 of 27502, by pentiumspeed
Since had worked with electronics, and little research on line, photos was invaluable of a original Deskpro 386/25e, I needed to map out the pin out of power supply on this motherboard received from ebay seller. Mystery of the 2 pins can be explained, one of them is for HD LED activity signal input to PSU that leaves one other pin for power good signal from PSU.
Completed mapping out the pinout for PSU input on the motherboard. Motherboard does not need -5V since -12V feed from PSU on motherboard is split off to feed a LM7905 regulator IC to generate -5V for the ISA bus and for serial port.
Hard drive LED activity is on one of the pins to light up the LED inside the PSU for hard drive activity. Now there is other pin is for power good signal from PSU that leaves me with 2 unknown pins, matter of a picking which is which for power good if correct motherboard will power up.
The PSU pin spacing is 3.96mm apart. The connector plug is female, needs 15 or 16 pins connector, one piece. Where can I get these? It is square pin not wide flat like the horrible IBM P5/P6.
Cheers,
Great Northern aka Canada.
Reply 14962 of 27502, by Bruninho
Does a 11-hour non stop working on code to get a Learning Management System (Moodle) custom theme to work on iOS 12.4 count as a retro activity? I never felt myself so angry. I tested even for iOS 10 and 11.
Turns out a small patch was done but not without much research. I’m losing my magic.
JOBS, Steve.
Reply 14963 of 27502, by ragefury32
Bruninho wrote on 2020-04-28, 04:16:
*oof*...
At least it’s not Blackboard Learn (competing LMS) That thing still gives me nightmares.
Reply 14964 of 27502, by ragefury32
The replacement GeForce 6200 PCI board came in the mail today along with my OLED display boards (20 days via Speedpak...is not speedy whatsoever).
Discovered that the standard/default soldering tip on the Weller soldering station is really too wide to work on small electronic boards. I had to solder 4 header pins on the OLED board for the Thinkpad Gotek and it was a royal pain trying to put a blob of solder precisely on the pins that I needed. Well, at least it works.
1.11 MiB
Done
Once the Gotek display was sorted out, managed to mess around with a few old OSes being tested on a pile of SD cards via the “open” Thinkpad 560E - none of the old UNIX installs work (AIX/PS2 is looking for a token ring card, AT&T SVr4 doesn’t boot) but got NT 3.51 installed. The Trident Providia worked but the ESS Audiodrive didn’t. Made the mistake of pulling the SD card (formatted to an ancient NTFS version) and putting it on my modern Win10 machine so I can copy some files over...eh, that for some reason corrupted the file system. Might need to reinstall on FAT32 the next time around.
The replacement GeForce 6200 PCI worked just fine on the t5720, but then I realize how mediocre the performance really was (tested it on UT2004, which is a DirectX 8 game) It was cheap, sure, but it wasn’t
going to go above 40 FPS. I think I have UT99 and Battlefield 2 here somewhere that I can fire up. Oh well, it was still better than the onboard SiS315.
Had a bit of a scare earlier - thought that the card died again when leaving it in the thin client will cause it not to boot. Turns out I tried to start the thin client with it plugged into the Thinkpad charger (whoops!). Swapped cables and it worked just fine. Oh well, let’s see how it performs with Win98 and older games. I’ll need to install the capacitors for the PCI riser if I want the AOpen YMF744 Cobra to work (not really a priority since my Thinkpad T21 does an okay job with OPL3 emulation.
Reply 14965 of 27502, by brian105
Ran speedsys on one of my Compaqs.
Presario 5284: K6-2+ 550 ACZ @ 600 2v, 256MB PC133, GeForce4 MX 440SE 64MB, MVP3, Maxtor SATA/150 PCI card, 16GB Sandisk U100 SATA SSD
2007 Desktop: Athlon 64 X2 6000+, Asus M2v-MX SE, Foxconn 7950GT 512mb, 4GB DDR2 800, Audigy 2 ZS, WinME/XP
Reply 14966 of 27502, by Almoststew1990
I caused a minor fire
Nothing is as reassuring as a lightly smoking PC case...
Reply 14969 of 27502, by Almoststew1990
Much prefer Sata over molex if I can (i.e. an XP build)! Molex is a wriggly pain! And Sata snaps into place reassuringly...
(although I much prefer none at all - my main PC uses M.2 slots which are beautiful!)
Reply 14971 of 27502, by Almoststew1990
I think I forced the sata cable in upsidedown because the vertical bit of the connector had snapped off the DVD drive. It was a bit stiff but still clicked into place like normal so I didn't think anything of it until it caught fire!
Reply 14972 of 27502, by dave343
Curious since I’m also building a 486 system, with an ISA card. How are you finding the speed in Duke3d and other games? Also, which ISA card do you have?
Reply 14973 of 27502, by appiah4
Is this a Trident card? They tend to do that on TFT panels..
Reply 14974 of 27502, by wiretap
kolderman wrote on 2020-04-28, 09:28:
wiretap wrote on 2020-04-28, 09:26:
I hate SATA power connectors.. 🤣
More than molex? That's unpossible.
For convenience factor, SATA is better, but as far as design and current capacity - SATA is worse. SATA tends to sag down and cause high resistance on the pins which leads to oxidation or burning. Molex secures tightly and creates a better electrical connection. As far as ratings, the Molex connection is usually rated at 132 watts (11 amps) whereas the SATA connection is usually rated at 54 watts (4.5 amps). Of course this also depends on meeting the spec, and how badly the Chinese manufacturers cut corners. This became apparent during cryptocurrency mining when people try using Molex to SATA adapters to power GPU riser boards and melted them or started fires depending on the graphics card PCIe slot power draw.
My Github
Circuit Board Repair Manuals
Reply 14975 of 27502, by LewisRaz
appiah4 wrote on 2020-04-28, 13:44:
Yes it is indeed a trident 8900C.
dave343 wrote on 2020-04-28, 13:08:
The card is an 8900C.
Duke3D is on the limit of what you might tolerate. Doom is very playable however. I also tested simcity 2000 which crashed after around an hour after becoming sluggish. And Transport tycoon deluxe which struggled with scrolling around the map but was playable. I would easily have tolerated the performance of TTD and doom back in the day, but not duke3d.
A member from another forum has offered me a dxs 66mhz so it will be interesting to compare that to the 50mhz SX. The system does also have 256kb cache.
Twitter
Reply 14976 of 27502, by appiah4
LewisRaz wrote on 2020-04-28, 14:01:
Known issue with no workaround, use a CRT or another card.. Sorry. 8900 is a fast card and I have one with 1MB RAM too, but the same issue prohibits me from using it..
Reply 14978 of 27502, by dave343
appiah4 wrote on 2020-04-28, 14:16:
How does the 8900 compare to the Cirrus Logic 5429? Also 1mb ISA.
Reply 14979 of 27502, by darry
dave343 wrote on 2020-04-28, 14:29:
I would take an ISA Cirrus Logic over a Trident 8900C any day . The 8900D is supposedly quite fast, but the previous models, not so much .
I used a VLB 5429 back in the day and had no compatibility issues, I can't comment on the speed of the ISA version or LCD compatibility . I did have a Trident 8900B before that and definitely would not have called it fast (then again OAK Technologies and Realtek ISA offerings were even slower) .
