As the subject says, I am trying to get the demo Amnesia by Renaissance to run on my Pentium 3 Tualatin 1400 with 512MB of RAM machine with caches disabled.
The readme says to run without emm386.exe or even himem.sys , so I have tried running with them on pure DOS 7.1 (Windows 98 SE), but I get a very helpful error message saying that 640KB of RAM is required . When I try to run with himem.sys, to load DOS high, I get the same error .
Next, I tried boot off a DOS 5.0 floppy and tried running the demo from a floppy and got the same error, whether running without or without himem.sys .
Just to be clear, both with my DOS 7.1 and 5.0 tests, nothing was being loaded from config.sys or autoexec.bat (except himem.sys when testing with it) .
Is the error message a red herring and the issue lies elsewhere (too much RAM, still too fast) ?
EDIT : I know it runs fine in DOSBOX
Some programs may fail if there's too much RAM. It may not like your 512 MB of total RAM, hence giving you a standard error that at least 640 KB are needed. The value of 640 KB does certainly not refer to the free conventional memory needed, as on a standard PC, you can never have 640 KB *free*.
Memory is not the issue with this, the message is misleading. It's a pain in the ass to run it on real hardware, your best bet is a real 386, it won't run on Pentiums even on many 486s regardless of speed (disabling caches etc won't help) . I don't know what exactly is the problem and therefore if something can be adjusted so that it runs, only that it doesn't.
I am well aware I can never have 640KB free. With himem.sys and umbpci.exe, I can get about 620KB free according to mem . I get about 550KB free when booting with shift-f5 (without himem.sys and with DOS loaded low) when using DOS 7.1 .
One thing that I have noticed is that I do not actually have 640KB total conventional memory on either the Ipox 3ETI23 or Asus P3B-F, according to the mem command, I have 645120 bytes total conventional memory on the Ipox and 634880 bytes on the Asus when using the same DOS 5.0 boot disk . My first reaction was "boot sector virus", but F-Prot 3.16 (definitions from 2005) finds nothing .
I can live with not being able to run Amnesia, but that conventional memory thing has got me worried . I was expecting 655360 bytes total conventional memory on both machines .
EDIT: I get 655360 bytes total in Virtualbox (using an image of the DOS 5.0 boot floppy), so not a bootsector virus .
EDIT2 : posted wrong output for virtualbox, now fixed
Ipox 3ETI23 (DOS 5.0 boot disk)
1MS-DOS Version 5.00 2Revision A 3DOS is in low memory 4 5 6 645120 bytes total conventional memory 7 645120 bytes available to MS-DOS 8 581680 largest executable program size 9 10 67043328 bytes total contiguous extended memory 11 67043328 bytes available contiguous extended memory 12 13Conventional Memory : 14 15 Name Size in Decimal Size in Hex 16------------- --------------------- ------------- 17 MSDOS 58352 ( 57.0K) E3F0 18 COMMAND 4704 ( 4.6K) 1260 19 FREE 128 ( 0.1K) 80 20 FREE 64 ( 0.1K) 40 21 FREE 581680 (568.0K) 8E030 22 23Total FREE : 581872 (568.2K) 24 25Total bytes available to programs : 581872 (568.2K) 26Largest executable program size : 581680 (568.0K) 27 28 67043328 bytes total contiguous extended memory 29 67043328 bytes available contiguous extended memory
Asus P3B/F (DOS 5.0 boot disk)
1MS-DOS Version 5.00 2Revision A 3DOS is in low memory 4 5 6 634880 bytes total conventional memory 7 634880 bytes available to MS-DOS 8 571440 largest executable program size 9 10 67043328 bytes total contiguous extended memory 11 67043328 bytes available contiguous extended memory 12 13Conventional Memory : 14 15 Name Size in Decimal Size in Hex 16------------- --------------------- ------------- 17 MSDOS 58352 ( 57.0K) E3F0 18 COMMAND 4704 ( 4.6K) 1260 19 FREE 128 ( 0.1K) 80 20 FREE 64 ( 0.1K) 40 21 FREE 571440 (558.0K) 8B830 22 23Total FREE : 571632 (558.2K) 24 25Total bytes available to programs : 571632 (558.2K) 26Largest executable program size : 571440 (558.0K) 27 28 67043328 bytes total contiguous extended memory 29 67043328 bytes available contiguous extended memory
Virtualbox 6.1 (DOS 5.0 boot disk)
1 2MS-DOS Version 5.00 3Revision A 4DOS is in low memory 5 6 7 655360 bytes total conventional memory 8 654336 bytes available to MS-DOS 9 590896 largest executable program size 10 11 32505856 bytes total contiguous extended memory 12 32505856 bytes available contiguous extended memory 13 14Conventional Memory : 15 16 Name Size in Decimal Size in Hex 17------------- --------------------- ------------- 18 MSDOS 58352 ( 57.0K) E3F0 19 COMMAND 4704 ( 4.6K) 1260 20 FREE 128 ( 0.1K) 80 21 FREE 64 ( 0.1K) 40 22 FREE 590896 (577.0K) 90430 23 24Total FREE : 591088 (577.2K) 25 26Total bytes available to programs : 591088 (577.2K) 27Largest executable program size : 590896 (577.0K) 28 29 32505856 bytes total contiguous extended memory 30 32505856 bytes available contiguous extended memory
I ran some more tests with a DOS 7.1 bootable HDD image in DOSBOX 0.74 and in an old build DOSBOX Daum (for the large RAM support) .
Observations :
When booted in DOS 7.1 :
- Amnesia runs fine with himem.sys loaded and 512MB of RAM in Dosbox Daum (did not check the sound).
- Amnesia runs fine with himem.sys loaded and 64MB of RAM Dosbox 0.74 (did not check the sound)
- The amount of TOTAL conventional memory in both cases is 640KB .
- The amount of FREE conventional memory in both cases is 602KB
My guess is that there is a check for TOTAL conventional memory in Amnesia . Why ? Who knows ?
DOSBOX 0.74 (running DOS 7.1)
1Windows 98 [Version 4.10.2222] 2Revision A 3DOS is in HMA 4 5Memory Type Total Used Free 6---------------- -------- -------- -------- 7Conventional 640K 38K 602K 8Upper 0K 0K 0K 9Reserved 384K 384K 0K 10Extended (XMS) 63,488K 68K 63,420K 11---------------- -------- -------- -------- 12Total memory 64,512K 490K 64,022K 13 14Total under 1 MB 640K 38K 602K 15 16Largest executable program size 602K (616,576 bytes) 17Largest free upper memory block 0K (0 bytes) 18MS-DOS is resident in the high memory area. 19 20Modules using memory below 1 MB: 21 22 Name Total Conventional Upper Memory 23 -------- ---------------- ---------------- ---------------- 24 MSDOS 17,216 (17K) 17,216 (17K) 0 (0K) 25 HIMEM 1,168 (1K) 1,168 (1K) 0 (0K) 26 DBLBUFF 2,976 (3K) 2,976 (3K) 0 (0K) 27 IFSHLP 2,864 (3K) 2,864 (3K) 0 (0K) 28 COMMAND 7,328 (7K) 7,328 (7K) 0 (0K) 29 KEYB 6,944 (7K) 6,944 (7K) 0 (0K) 30 Free 616,704 (602K) 616,704 (602K) 0 (0K) 31 32Memory Summary: 33 34 Type of Memory Total Used Free 35 ---------------- ----------- ----------- ----------- 36 Conventional 655,360 38,656 616,704 37 Upper 0 0 0 38 Reserved 393,216 393,216 0 39 Extended (XMS) 65,011,712 69,632 64,942,080 40 ---------------- ----------- ----------- ----------- 41 Total memory 66,060,288 501,504 65,558,784 42 43 Total under 1 MB 655,360 38,656 616,704 44 45 Largest executable program size 616,576 (602K) 46 Largest free upper memory block 0 (0K) 47 MS-DOS is resident in the high memory area.
I removed the hard disk controller (PROMISE Fastrack S150 SX4, as the machine normally runs XP) from the P3B-F machine, booted from a floppy again (DOS 5.0) and guess what ? 655360 bytes total conventional memory !
I ran Amnesia.exe and it worked !
So Amnesia really has a (IMHO pointlessly irritating) check for TOTAL conventional memory and if you don't have 640KB, you are SOL .
The issue is probably similar in my other system, where I have a SIL3114 SATA controller, which probably decreases the conventional memory pool by 10KB .
Just for fun, I threw all of the exe unpackers I could find at the amnesia.exe, but nothing worked, so it probably uses some custom exe packer or obfuscator . I was hoping it might be easy to patch, but apparently not .
Fun fact: Amnesia does not run for me at all (black screen) on a Voodoo 3 (VGA) , but works fine on a Geforce FX 5900 over DVI . Nice demo, but picky .
