Working on a water cooled Athlon system.
Reply 20 of 64, by austinham
LET THE MODDING BEGIN!
OK, so the AT cases motherboard tray will not safely old a ATX board. So I will have to replace that, The stock fittings on the radiators are some sort of plaited ferrous metal as they are magnetic. So OFF with their heads... er fittings...
I got one rad done and ready for leak testing, 4 more to go !
Reply 22 of 64, by austinham
chrismeyer6 wrote on 2020-05-06, 17:03:
Nice job can't wait to see the finished system!
Thanks.
I can't wait ether. I hope the mother board is good, I recaped it about a year ago with what I had on hand and wile I used good caps the UF ratings were higher on a few caps ans I have not clue what the right ratings are now. At lest it posts !
Reply 23 of 64, by austinham
The build as it stands 5-7-20.
I picked up and abit nf7-sg2 to use in place of the kg7. The KG7 has a much slower FSB agp 4x and was recapped with higher rated caps. I thought it would be better to just get a newer/better motherboard for the system.
P.S. if anyone wants the kg7-raid shoot me a PM. I don't need it anymore and Id hate to see is hit the garbage pile.
Reply 24 of 64, by austinham
The build as it stands 5-8-20.
Not much to say today. I got fittings soldered on a 3rd radiator, I'll get the 5.25 to 3.5" bay hdd adapters today along whit some floppy disks for setting up the HDD controllers drivers in the windows 98 installer. I hope to get the last 2 radiator fittings soldered on over the weekend.
Part2:
I have all the fittings soldered on the radiators. Two radiator have 3/8" fittings for the CPU loop and 3 radiators have 1/4" fittings for the chipset/GPU loop.
Once the radiators cool off and I get them all cleaned up and leak tested I'll post photos of them.
Reply 25 of 64, by austinham
The build as it stands 5-11-20
Not much to add. I got a pci sata card in the mail that I'll use to add a 3rd sata hdd to the system. I removed the motherboard tray from the case to replace it with a new one. I should also get the ATX motherboard tray and I/O panel in the mail today as well. I order on from Mountain Mods as making a tray and I/O panel is not all to fun.
I still have yet to clean up and leak test the radiators. The fittings are however all soldered on.
Reply 26 of 64, by austinham
The build as it stands 5-12-20
I got the NF7 board today. Looks to be in good shape. The motherboard tray and I/O panel I got from Mountain Mods will be a perfect for converting the case from AT to ATX. I hope to get the rear AT I/O panel off case tonight. As of now the case's motherboard tray and cross support beam has been removed.
Reply 27 of 64, by austinham
The build as it stands 5-13-20
I have the case halfway covered to ATX. I need to make a few brackets to hold the motherboard tray down.
I still need to knock out the holes for the radiators too. Once I get that all done I'll post photos of the case.
Reply 30 of 64, by austinham
melbar wrote on 2020-05-13, 18:44:
Interesting project !!!
Which Xp do you want to use? T-bred? Barton? Desktop or mobile version?
I was going to use a Thorton 2400+ but since I got the nf7 I'll try and find a 3200+ Barton. Since I have a NF7-SG2 I'll be using a desktop version, the SG2 version of the NF7 is not mobile friendly.
chrismeyer6 wrote on 2020-05-13, 20:16:
Looking good. Definitely looking forward to seeing the finished system!!
Thanks.
Reply 31 of 64, by Jackhead
I work at the moment also on a watercooling mod, but an AIO. I used a Corsair H100i Platinum on a Asus A8V deluxe sockel 939. Works perfect, i used the intel clamps, and removed the bracket. It needs also some modification on the backplate screws, but with a dremel np 😀 Goal is a Athlon FX-57 with a HD3850 system for WinXP. CPU temps with the cooler are around 35° idle, and on load up to 50° (Silent).
1.73 MiB
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - AMD A5x86 X5 ADZ 133MHz @160MHz - 64MB RAM - CT2230 - GUS ACE - MPU-401 AT - ET4000W32P
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI @ 66MHz PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
Reply 33 of 64, by Jackhead
im sorry dont want to crush your thread, its just i read athlon water cooling. Research on that topic brings not really much up. Nice project btw!
Reply 34 of 64, by austinham
Jackhead wrote on 2020-05-14, 13:00:
nah your OK. But it would be cool if you made a thread about your build. Water cooled 939 systems wile were once a normal thing and are now a rare find.
Here are a few links I have on water cooling old Athlon systems you may find useful.
https://www.webx.dk/oz2cpu/pcmod/water.htm
http://www.nyx.net/~smanley/watercool/index.html
http://www.madshrimps.be/articles/article/344 … p#axzz6MQA1YyoY
https://www.youtube.com/watch?v=zinYRdRXst4
Reply 35 of 64, by Tali
I'm sorry if I did offend you by using the word "wreck". But what I meant with it was any destructive (as in "irreversible", no matter how well made) modification on something so old and rare is a step not taken lightly.
Reply 36 of 64, by austinham
The build as it stands 5-15-20.
Nothing really to add today, been taking a brake from the system to work on my car and some other stuff.
But here is a list of games I have for the system.
amok
Age of empires 1
Apocalyptica
blood
Chex Quest
CS1.6
doom 1 and 2
Duke Nukem 3D
Evlva
gnome
Great Qin Warriors
half life 1
lemmings
Mech warrior 2, 3 and 4
Prisoner of War
Quake 1, 2 and 3
Resident Evil 1, 2 , 3 and 4
Road rash 3d
Shatered steel
silent hill 2 and 3 (still trying to find the first for good deal)
Starship Troopers
Dark Forces 1, 2 and Jedi Academy and outcast
KOTOR 1 and 2
Star Wars Episode I Racer
Rogue Squadron 3D
TIE Fighter
xwing
Tie V xwing
Battlefront 1
System Shock
Populous the beginning
The Elder Scrolls Arena and Elder Scrolls 2
Simpsons Hit and Run
Turok 1, 2, 3 and 4
Unreal Tournament
postal 1 and 2
Lords of Magic
Battlecruiser 3000AD
Some other apps I'll have on the system.
CPU-z
HWMonitor
KernelEx-4.5.2
pstrip (full version)
UnrealEditor
CCleaner-2.36.1233
DTLite
SpeedFan
Reply 37 of 64, by austinham
The build as it stands 5-17-20
I bought a new part for the build, M-systems 4000 2gb IDE ssd's.
I bought 3. 2 will be used in raid 1 and one will be as a spare. I wanted the 3000 model but couldn't find them.
Other then that nothing else to add.
EDIT:
I cancelled the order for the SSDs after finding out how slow they were.
Reply 38 of 64, by austinham
The build as it stands 5-18-20
Not much to add, I got a sound blaster audigy for the system.
As of today I still need to get the pumps, tubing, a few fittings, coolant, 44pin to 40pin IDE adapters and 2.5" to 5.25" bay adapters. I also still need to mod the case to fit the rads.
Since the case has a CPU speed turbo display and being 3 digit its of little use for the build. So I'm thinking of using it for a post card display or converting it to a 4 digit display. I'll likely use the turbo button for a power button and the AT power switch to power on auxiliary fans.
Reply 39 of 64, by austinham
The build as it stands 5-19-20
Still not much to add today. I had ordered two audigy's for the system, a audigy 1 SB0090 with gold ports and audigy2 with the somewhat hard to find midi game port cable. Sadly the seller of the ladder backed out. However I found a little gem know as the SB0160 witch had the midi game port on the card.
I'll likely solder the gold ports from the SB0090 I orders on to the SB0160 and call it a day.
I'll be pump, fitting and tubing shopping today, so stay tuned for more info.
