CrystalBlaster C1
First post, by dreamblaster
i completed a new project : CrystalBlaster C1
This was created with the help of a friend Ivo, hence the name "Ivo Limited Edition".
It has a 90s low end wavetable synthy sound, as it uses the Crystal CS9236 chip :
CS9236 specifications :
  • General MIDI (GM) compliant
  • 32-note polyphony at 44.1kHz rate
  • Independent reverb and chorus levels for each MIDI channel
  • 128 melodic instruments and 47 percussion sounds
I recorded a demo (grab bag from duke nukem 3d) :
https://youtu.be/jXHmRXtgH9g
In my opinion, it is a fun soldering project with a unique sound,
but the dreamblasters certainly do sound more realistic..
I will make some available as an easy 100% through hole solder kit (I will presolder the SMT DAC)
at this link : https://www.serdashop.com/CrystalBlasterC1
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
Reply 1 of 7, by keropi
interesting for DIY lovers for sure , will grab one 😁
Reply 2 of 7, by dreamblaster
Here's a soldering video, with a lot of Crystalblaster C1 music, by pc-sound-legacy :
https://youtu.be/09nEmwcwR0k
Reply 3 of 7, by Ulfenknulfen
Pretty cool.
Sounds crystal clear without any distortion.
Thanks a lot!
(The sockets for hex inverter and quartz I still had...)
best regards
Paddy
download/file.php?mode=view&id=112032
download/file.php?mode=view&id=112033
🎵 Waveblaster Adaptor for IDE-HDD Swap Frames
🎧 Beepblaster 1.0, 2.0 Wavetable Module
🎶 Roland MT-32 Buffer overflow Hardware Fix
🕹️🖱️USB HID Devices on PS/2 and Gameport.
Reply 4 of 7, by dreamblaster
I prepared 2 last kits. After this, CrystalBlaster C1 will move to the museum as well.
Reply 5 of 7, by dreamblaster
OK the last 2 kits are gone, CrystalBlaster C1 moved to the museum
https://www.serdashop.com/Museum
Reply 6 of 7, by subnet_zero
This was one was great to solder and hear. Oh, you forgot to mention "Crystal Blaster C2 coming soon...". 😉
Reply 7 of 7, by dreamblaster
subnet_zero wrote on 2021-07-13, 10:56:
Ah yes I am planning C2 version, not sure how soon, but it will come.
