First post, by GL1zdA
- Oldbie
I have a slight problem with my AWE32. I'm using my Intel Advanced/EV motherboard (430FX chipset), which has a Vibra 16S on-board with a goldfinch upgrade (CT1920). This configuration uses all the defaults (A220 I5 D1 H5 P330 E620 T6) except for one: it won't work with the EMU8000 at 620h. It will work at every other port (640h, 660h, 680h) but if I set it to 620h, I will get the yellow exclamation mark in Device Manager saying the device is not present or doesn't have drivers installed. There are no conflicts, Windows doesn't report any device using 620h. Any idea what is wrong? How can I pinpoint what makes 620h unusable?
