Reply 15140 of 32080, by EvieSigma
Well, 1991 is when System 7 first came out in the form of System 7.0...but yeah, the fact that OS 9 worked at all in the late 90s/early 00s is kind of a miracle.
Reply 15141 of 32080, by ragefury32
Well, more dispatches from the war to teach old routers (Imagestream Transport/Portwell NAB-2050) new tricks - finally able to get it to work, and all it took was for me to reinstall Windows 98, and through a series of safe mode troubleshoots, disable 2 of the network ports and that useless unpopulated PS/2 mouse port. Turns out one of the NICs grabbed the IRQ used by the video card and another the DMA channel on the IDE...no wonder every time I tried to boot it it’ll lock up on normal mode until I discovered that whoopsie.
The attachment D30C5950-EA93-4668-A24D-F4B053089D91.jpeg is no longer available
So, what can you do with an old Via ESP5000 (basically like an Epia-M but at half the clockspeed...?)
Well, you could keep out the Nazis...
The attachment F2A86AF9-EA9E-41BE-A7AE-C4BC137BD153.jpeg is no longer available
You could filter out the Stroggos...
The attachment 55792473-9649-4CC4-BAD7-FD8878ABA42E.jpeg is no longer available
You could also run on top of large alien artifacts....
The attachment 65A7964F-406C-42EC-A46B-4164ADC4E7EF.jpeg is no longer available
Or you can act the fool on top of tall buildings...
The attachment 990E624E-D582-424B-92B9-3999F230D55D.jpeg is no longer available
BTW, in case you are wondering, those numbers are done at 640x480@16bpp - single digits at UT99, 15 fps on Quake 2. I have no idea if it’s the 533 MHz Via Samuel 2 failing the integrated Trident CyberBlade i1, or the CyberBlade failing the Samuel 2. I am going to pick up some 400MHz DDR SODIMM modules and see if memory speed improvements will help. But either ways, I need a working audio card. The YMF744 from AOpen was...silent. Not sure if it’s the missing caps on the PCI riser, something wrong with the card, or the card was damaged by the broken t5720 board.
Reply 15142 of 32080, by mastergamma12
Playing around with my ELSA 3d Revelators.
Reply 15143 of 32080, by bjwil1991
Modified my newly acquired PB450 board with the 3.3V CPU support, except I don't have any spare DX4-100 chips that supports 3.3V CPUs.
Reply 15144 of 32080, by Bruninho
EvieSigma wrote on 2020-05-10, 02:31:
The real miracle was seeing Windows 3.11 being still used in a french airport. And guess what? Yes, you guessed it right. It crashed on them.
https://www.zdnet.com/article/a-23-year-old-w … -paris-airport/
Pretty shocking.
Speaking of the demon (Windows), I am doing a Windows XP Pro VM for some retro gaming.
JOBS, Steve.
Reply 15145 of 32080, by Caluser2000
Bruninho wrote on 2020-05-10, 05:37:
The real miracle was seeing Windows 3.11 being still used in a french airport. And guess what? Yes, you guessed it right. It c […]
Pretty shocking.
What is shocking about it? It appears to have worked quite well until then when maintained properly.....That is pretty dame good indeed considering the increase in air traffic over the time it was in service..
Reply 15146 of 32080, by kolderman
Plain old DOS is still used in places. Complex applications can be extremely expensive to rewrite.
Reply 15147 of 32080, by Caluser2000
computerguy08 wrote on 2020-05-09, 21:31:
I unsuccessfully tried to set up a LAN bridge adapter for my retro rigs with an OpenWrt router using relayd. No matter what I tried I couldn't get an internet connection on the LAN ports.
Just use a 100/10 switch between your old systems and internet router. KISS
Reply 15148 of 32080, by Bruninho
Caluser2000 wrote on 2020-05-10, 05:41:
Pretty shocking.
This is exactly why I am shocked. That damn thing worked so well for them in 23 years. Hats off to Microsoft for the longevity of their OS, at least.
JOBS, Steve.
Reply 15149 of 32080, by Caluser2000
Bruninho wrote on 2020-05-10, 06:04:
Pretty shocking.
The actual OS was Dos. Win3.1 was a graphical desktop environment sitting on top of it.
Reply 15150 of 32080, by xcomcmdr
It's more complicated than that, but whatever.
Reply 15151 of 32080, by brian105
Cleaned my Presario 5284 fully by disassembling basically everything including the PSU. And I somehow didn't kill it! Although somehow I was smart enough to set the clock multi jumper to 2.5 rather than 5.0.
Presario 5284: K6-2+ 550 ACZ @ 600 2v, 256MB PC133, GeForce4 MX 440SE 64MB, MVP3, Maxtor SATA/150 PCI card, 16GB Sandisk U100 SATA SSD
2007 Desktop: Athlon 64 X2 6000+, Asus M2v-MX SE, Foxconn 7950GT 512mb, 4GB DDR2 800, Audigy 2 ZS, WinME/XP
Reply 15152 of 32080, by Bruninho
Caluser2000 wrote on 2020-05-10, 06:12:
Yes! I keep forgetting that.
Btw I am currently updating a XP VM. I might make a topic to talk about my VMs, instead of spreading it across the topics... That way I can share my experience with them and my findings. Pretty much like a topic on MSFN forums called "Running vanilla Windows 98 in 2020" from another user, except that I might not go "vanilla" exactly... ah, I will actually create the topic. It should be fun, I will not be running just Windows, but also a certain Linux distro and maybe OS/2 Warp 4 and for sure any old macOS (System 7? OS X 10.4 Tiger?)
JOBS, Steve.
Reply 15153 of 32080, by derSammler
That is just as wrong as it is right. There's no definite definition of what makes an OS. Windows 3.x uses its own drivers for sound, graphics, input, etc., has it's own SDK and applications (which don't run in DOS), can interact with the hardware directly (32-bit disk access, WinG for hardware-accelerated graphics) and what not. It's quite a stretch to call it "just" a GUI or GDE.
If Windows was just a GUI, then MacOS 10/X is too by the same definition. Because below is Darvin, a fork of BSD UNIX taken from NeXT, which is the actual OS running.
Reply 15154 of 32080, by appiah4
I got started on recapping my MSI KT3 Ultra 2 motherboard. Desoldering went a lot easier than I thought with just a cheap soldering iron, a solder pump and some solder wick.
MSI-KT3-Ultra-2-Decap-01.jpg MSI-KT3-Ultra-2-Decap-02.jpg MSI-KT3-Ultra-2-Decap-03.jpg
Finally rid of those bulging, leaking pesky Teapo caps. Next step will be installing shiny new caps and building a totally overkill Barton 2500+ Voodoo 3 3000 PC with this.
Reply 15155 of 32080, by Vegge
Today I cleaned up the free 386 board I got yesterday. The batteryleakage was not as bad as it looked. Most of the stuff were just parts of the batteryleads stuck in the dust on the board. Just a quick clean, some scraping, added solder to cleaned traces and shes up and running. 😀
The attachment IMG_5462.JPG is no longer available
The attachment IMG_5461.JPG is no longer available
And while I was at it I dug out another 386 I started on over a year ago. I had already cleaned it and removed the very corroded keyboardconnector. So I just took the connector of a donorboard and that too boots just fine. 386sx25 with math-co.
The attachment IMG_5470.JPG is no longer available
The attachment IMG_5469.JPG is no longer available
The free 486 board I got yesterday is a little worse. Needs a more thorough cleaning to see if it's fixable.
The attachment IMG_5468.JPG is no longer available
Reply 15156 of 32080, by astonsmith
perhenden wrote on 2020-05-09, 19:57:
It's currently at MS-DOS 3.2, but this image can be booted in qemu, so now I can make it all good and perfect for my sweet Amstrad 😀
Sweet, I used to have a 1512. PCem has an Amstrad 1512 (& 1640) mode, which I found to be quite good at emulating the machine. The HD in mine died so I don't have a real image to boot with it, but all the floppies work (inc DOS Plus).
Reply 15157 of 32080, by Horun
Vegge wrote on 2020-05-10, 13:07:
Good work on those 386 boards !. This 486 looks too far gone to fix but maybe not. I have one that is similar and the corrosion spread under the kb controller and simm sockets so am not going to fix it since it only supports 5v 486.
Reply 15158 of 32080, by perhenden
astonsmith wrote on 2020-05-10, 14:58:
I can recommend the XT-IDE CF card I bought on eBay, it just worked 😀
ISA CompactFlash Adapter  IDE for 8Bit PC, XT CF LITE 4.1,  XTIDE Bootable https://ebay.us/HoFWHj
Reply 15159 of 32080, by aha2940
Horun wrote on 2020-05-09, 20:01:
aha2940 wrote on 2020-05-09, 15:49:
For whatever reason, today I decided to test some broken hardware yet again and found that an Antec power supply I thought was good, is indeed bad and a couple floppy drives that threw errors everywhere, are indeed OK after testing them with another PS (they throw errors when used with the Antec PS).
I just received replacement caps for my 2004 Antec 480w, it has lower volts on the +5v (at ~4v) and +12v (~9v) rails than should be and two caps look a little bloated/leaky. Unfortunately the caps that arrived are 12.5mm and I thought ordered 10mm (originals are 10mm and very tight fit in the PSU) so not sure if I can recap with them without possibly piggy-backing two caps off the board near a coil and run wires instead of straight thru the mount holes. If you can hook an old broken HD to the Antec or use a PSU tester check the volts and I bet one or more are too low.
I looked online for the capacitors needed to recap my Antec 350W, and found this page where a guy recapped a PS exactly like mine: https://www.badcaps.net/forum/showthread.php?p=89628
Unfortunately, that's a lot of caps, which would be pretty expensive to buy locally (a single one of the big capacitors may cost about 12 US dollars around here, and I'm talking about just replacements, they are not even Nichicon/Panasonic) so that would make the cost of recapping (fixing?) the PS way more than a new one. Maybe later I'll lookup into bringing all the capacitors from the US, that may be less expensive.
