First post, by perhenden
According to my memory, we had more than 600k free under MS-DOS on our Amstrad PC1640, as reported by the mem command.
Now, I can't seem to get more than 561k.
The usual tricks of using himem.sys and dos=high,umb does not work for me , as himem reports "requires 80x86", and .. "cannot load dos HIGH". I have an 8086-2 CPU.
Output from mem says 0 -zero- in all memory areas, other than conventional. What remains is the traditional 640k minus what DOS and a default install of MS-DOS (setver and more) uses.
Is there a way of loading DOS and other TSRs in an area above the 640k on this machine?
Am I wrong when I recall having 600k available under MS-DOS 6.22? Was there some memory upgrade available for PC1640 that gave us a bit more ram? I think we had some EMS ram reported in the mem command output.
Reply 1 of 4, by Zup
Your Amstrad PC1640 has only 640Kb. No area above 640k on this machine. Even if you install an EMS card you probably won't get high memory.
Himem.sys needs a 80286, and EMM386 a 80386. Remember that you have a 8086... they won't work.
I'd recommend you to use MS-DOS 3.x (Amstrad PC1640 system disks had MS-DOS 3.2) to maximize your free memory.
I'm selling some stuff!
Reply 3 of 4, by thierry
In my XT I have an EGA board installed, I also installed a clone Hercules board, with USE! UMB with DOS 5.0 leaves me free 32k of high UMB memory that takes them from the hercules board, there with DOSMAX I upload files, fcbs, command shell com, buffers, etc. to the UMB. + drivers mouse, doskey, etc and it leaves me free 595936 bytes which is quite good, the memory of the hercules board is slow, but in this case as they are drivers that I upload it works perfectly.
Reply 4 of 4, by mkarcher
perhenden wrote on 2020-05-10, 18:21:
Quite likely you are wrong if you combine MS-DOS 6.22 and the PC1640. You can have 600k available under MS-DOS 6.22 easily with DOS=HIGH,UMB (likely even with just DOS=HIGH), but this requires a 286 computer with more than 640KB of RAM. With just conventional memory, you are stuck where you are. On the other hand, remember that DOS 6.22 came out around 1994 (if memory serves me right), and the typical time to use an XT (at least in Western Europe and the US) was around 1986-1991. Many XT computers were used with DOS 3.3, which is a good fit for the capabilities of that computer. DOS 3.3 is considerably smaller than DOS 6.22, and it is quite likely you can get more than 600k free when you boot DOS 3.3 on the Amstrad PC1640.
