root42 wrote on 2020-05-12, 08:55:
Mouser usually ships for free for orders over 50EUR. Not sure about Turkey. I bought the whole Snark Barker BOM with Mouser and had no shipping costs (albeit for two SBs).
I think it would be enough if you found a small pot with similar layout. You could alternatively solder in two resistors for the time being. A potentiometer is kind of a voltage divider, right? So only one resistor wouldn't be enough I think.
I ordered the other stuff locally so this would be a bit steep 😒
I don't hink it's a very simple bypass, the board uses a dual gang potentiometer.
What I can make of this circuit schematic is that I can solder two 4.7KR resistors between 1A-2A and 1B-2B, the connect 3 to Ground and have it at 50%? Obviously as it is reverse logarithmic I would probably get what, 30% or so? Alternatively I could use an 8.2KR and 2.2KR but I don't know which one should go where to get around 70% volume..
I followed the traces to label the terminals above..
