Well this is fun, and by fun I mean really really dumb.
Tried the USB20DRV.EXE package and that gave me the correct VIA 6202 Enhanced Host Controller entry in Device Manager, however despite being disabled the BIOS the onboard USB1.0 still shows up, 2 entrys in fact ? and the kicker is the 6202 entry has the yellow exclamation mark to so something still is wrong..
Tried various PCI slots as I cant actually edit the IRQs of anything relevant in the Device manage for some reason ? I get a "Resource can not be modified" error..
Also pulled the Opti Firelink USB1.0 card from my old Power Mac 7600 in desperation and that simply will not work despite showing with no errors in Device Manager ?
The TLDR is, none of this works properly in terms of USB.. none of it, no matter what I do.
May fall back to the Voodoo 2/Matrox PCI combo as I hear early VIA chipset support for AGP can be bad and that may feed in to my issues ?
And if THAT does not work then I am going to try Windows XP as a very last ditch attempt as that is the newest Windows version I can get away with running on this machine I figure and if THAT does not work well I think I need to find a different Super Socket 7 Motherboard or go to Slot 1 or something ? .. may be more in keeping with the Voodoo 3 AGP anyway. .
