Munt with CM-32L
First post, by r90223038
I am now using mt32emu_win32drv-0.1.3 with MT-32 ROM. How should I change to a CM-32L ROM.
Now I simple changed the file name form CM32L_CONTROL.ROM to MT32_CONTROL.ROM and CM32L_PCM.ROM to MT-32_PCM.ROM in windows/system32 directory. It seems everything is OK in DOSBOX.
However, does anyone know the "Offical method" to change it?
Reply 1 of 1, by zbiggy
If you want CM-32L emulation with munt and have ROM files do not rename anything. Just copy CM32L_* files to windows/system32 directory where MT32* files are already. Munt autodetects CM32L_* files and use them instead of MT32_*.
