First post, by BreakPoint
Looking for SOYO SY-5TH manual.
My CPU collection - Looking for hardware in Ukraine - Ukraine vintage PC forum
Reply 1 of 15, by Baoran
Never heard of that one existing. Do you mean Soyo SY-5EH? Do you have a picture of it?
Reply 2 of 15, by Doornkaat
I hope the attatched file is the manual.
You can look for old manuals, BIOS and drivers yourself using web.archive.org and selecting a website image from the time range your product was supported.
Have fun! 😀
Edit:
It would appear there's a Soyo 5TH(0/2/5) that I had the manual for. I haven't found a booard called "SY-5TH".
I also found a BIOS image using archive.org which I will also attach. Had to create an archive because the forum won't let me upload a .bin file. Check wether the manual bescribes your board before attempting to flash (at your own risk of course. 😉 )
Reply 3 of 15, by evasive
Soyo boards of that era go by at least three different names, for instance the 20N can be 020N, 020N2, SY-020N2 etc. SY is simply added for SoYo. I have 2 more manuals with TH5 in the name:
https://www.elhvb.com/mobokive/Archive/Soyo/m … /586/index.html
And 4 different bioses with th5 in the name:
https://www.elhvb.com/mobokive/Archive/Soyo/b … /586/index.html
If I can find time I'll extract the bios strings from them.
Reply 4 of 15, by evasive
5TH1021.BIN : 10/21/1998-i430HX-2A59FS2DC-00
128K TH-1021
5TH0827.BIN : 08/27/97-i430HX-2A59FS2DC-00
128K TH-0827
5TH-B.BIN : 09/17/96-i430HX-2A59FS2DC-00
128K TH-B
5TH-C.BIN : 04/29/97-i430HX-2A59FS2DC-00
128K TH-C
so the 1021 seems to be the only one that is 2yk compliant. I have patched it for larger disk support (up to 128GB per disk) if anyone is interested.
Reply 6 of 15, by evasive
@Breakpoint can you please make a backup of your bios as we don't have that version yet. Feel free to use either Doornkaat original 1021 or the 128GB disk patched bios afterwards.
Reply 7 of 15, by Doornkaat
evasive wrote on 2020-05-17, 10:08:
That's mighty nice of you!
I always thought about looking into modding BIOS for LBA support as well. Is it rather straightforward or am I going to end up with a bunch of bookmarks and a half finished project again? 😁
Reply 8 of 15, by evasive
There are two options: one is you do a request on the forums at wimsbios.com for a patched bios or two you go to rom.by and get the patcher there that also patches more multipliers and support for other CPUs in your bios. The patcher used at wimsbios is _almost_ foolproof, success rate on the rom.by patcher is near 95% and improving.
Reply 9 of 15, by Doornkaat
evasive wrote on 2020-05-17, 18:05:
Thanks, I never knew there was a tool ready to use.👌
Reply 10 of 15, by Am386DX-40
Sorry for the slight necroposting, but I just got one of these motherboards (looks really cool)!
I'm trying to collect all these socket 7 Soyos with all the different chipsets, so far I have the 5TE (FX), 5TF (HX), 5VA (VX), 5VC (VX), 5BT (TX) and now the 5TH (HX, dual).
While checking the manual (which is very very similar to the others) I noticed that it only mentions it supports Pentium and Pentium MMX processors. Now I understand that the only socket 7 processors that support SMP on the HX chipset are Intel's, so If I want to run 2 processors that would be my only choice (which matches what the manual says). But what if I want to run only 1 processor? Can I use a 6x86 or a K5 or 6?
I have checked the bios with a hex editor for traces of 6x86 or k5 strings and found nothing, but I did the same on the bios of the 5TF (same chipset, only 1 socket) and I can't find anything either, though I know it supports it (as per the manual and actual experience).
Should I just go and try one of these cpus and see if they work? Will I fry anything? Is there a safer way to find out?
Reply 11 of 15, by chrismeyer6
I know the K6,2,2+,3,3+ don't support SMP not sure about the 6X86
Reply 12 of 15, by evasive
As long as you set the proper core voltage it should not fry anything. However, having said that, you can only use 2.8V core voltage.
Reply 13 of 15, by mkarcher
Doornkaat wrote on 2020-05-17, 09:00:
No board was sold as "5TH": That board was sold as 5TH0 if no L2 was installed (soldered on this board) at the factory, it was sold as 5TH2 if 256K of L2 cache has been installed at the factory and as 5TH5 if 512K of L2 cache was installed at the factory. That's a convention Soyo used on most of their 486/586 mainboards. So the 5TH(0/2/5) manual is the correct manual for all of the three editions of the board. As the board of the OP has two UM61L3264F chips installed, the board of the OP is a 5TH5.
Reply 14 of 15, by Doornkaat
mkarcher wrote on 2021-05-29, 20:46:
The documentation/files I found did not include the newer Soyo naming scheme with the SY- prefix despite the silkscreen on the board identifying the it as SY-5TH (as we found out later when the OP posted pictures). Later Soyo boards included that prefix in all documentation so I was clarifying what board the files in my post belonged to in case Baoran was right that the OP mistyped another model. I didn't want OP to end up with a bricked board due to a bad flash with files I provided.
It wasn't about the cache suffix.
Reply 15 of 15, by Sphere478
Has anyone been able to overclock this board?
There is also jan, (chkcpu) 😀
http://web.inter.nl.net/hcc/J.Steunebrink/k6plus.htm
Re: Diy modding support for k6+And 120gb hard drives into bios roms
Am386DX-40 wrote on 2021-05-28, 20:03:
Sorry for the slight necroposting, but I just got one of these motherboards (looks really cool)! I'm trying to collect all thes […]
it should work, buy may require bios patching for newer models.
chrismeyer6 wrote on 2021-05-29, 00:31:
none of the brands or models of cpus that I have tried have worked in dual except pentium with the exception of tillamook. Those don’t work. Odly, they do work with two but only as one, but other brands just don’t post.
So recap, only pentium before tillamook.
Sphere's PCB projects.
