Reply 15460 of 29871, by aha2940
- Member
derSammler wrote on 2020-05-22, 18:38:Err... no. Neither the first Action Replay from 1995, nor that very late Equalizer (which is the same, they just changed the nam […]
aha2940 wrote on 2020-05-22, 17:38:Likely because modchips are cheaper and work with all PS1 models (even the ones that do not have the parallel port).
Err... no. Neither the first Action Replay from 1995, nor that very late Equalizer (which is the same, they just changed the name) were more expensive than a modchip and paying someone installing it. And unlike with the latter, you did not lose warranty and got additional functionality.
The PS1 models with no parallel port are not relevant. The PSOne was released in 2000 when the PS2 was already close to being sold. The only other PS1 with no parallel port was the SCPH-900x, which was not very common and interestingly released before the SCPH-750x, which (still/again?) had the parallel port and was the model that was sold until the PSOne came out. You were also not forced to buy a model without a parallel port. Besides, many modchips stopped working with the SCPH-700x series and new ones were required, which were not available until months later.
I'm pretty sure it was more about knowing about modchips and these cartridges. Modchips were a big deal back then and everyone knew about them. The Action Replay on the other hand was probably not widely advertised. And if, they certainly did not advertise that it will play backup copies. Or maybe they did, Sony sued, and that's why it was no longer called "Action Replay" at some point. No idea.
Well, here in Colombia, the modchips were way cheaper than the Action Replay / Equalizer. That, added to the difficulty of finding one, made the modchips very popular.
