Reply 220 of 453, by derSammler
The SD-20 doesn't even have flash memory either, it can't store any settings. The "SD-20 Editor" is used for that.
Reply 221 of 453, by cyberaxe
Recently got an MT-32, SC-55 and SC-88, glad i saw this post, will open them up and check before I turn them on
Reply 222 of 453, by niki_iv
Glue.. Not corrosive
Reply 223 of 453, by derSammler
Context? Or did you just posted some random words?
Reply 224 of 453, by thierry
derSammler wrote on 2020-05-24, 08:31:
I suppose he meant that it has glue and it is not corroding, I don't know if I agree, my SC-155 had the battery changed and there was an acid thread that almost came off the logic board.
Reply 225 of 453, by derSammler
I assumed something like that, but it seems strange that someone with 9 posts in 9 years comes out of nothing claiming that this whole thread is moot and what we see is only glue. As if Roland (or any other company) would be so dump to put glue on a battery that firmly sits in a battery holder... It's of course leaked electrolyte from the coin cell.
Reply 226 of 453, by CrossBow777
cyberaxe wrote on 2020-04-07, 09:11:
The MT-32 doesn't have an internal battery unless it has been modified. But you might want to look into replacing the caps on it at some point as there are kits available for the MT-32.
Midi Modules: MT-32 (OLD), MT-200, MT-300, MT-90S, MT-90U, SD-20
Reply 227 of 453, by Jackhead
i checked my SC-88 Pro when i bought it, and the battery was leaking. Lucky there was no damage on the board..
Reply 228 of 453, by HandOfFate
Jackhead wrote on 2020-06-14, 12:36:
*Gulp*. I didn't know the SC-88 Pro also has one. I'll have to check tonight.
My SC-55 did have a swollen battery but no corrosion or other damage, fortunately.
Am486 DX4 120MHz, no L2, 16MB, Tseng ET4000/W32 1MB VLB, ESS ES1869 /// 5x86 133MHz, 256kb L2, 64MB, S3 Virge/DX 4MB PCI, SB16 + Yucatan FX, PicoGUS /// Pentium III 1GHz, 512MB, Asus V7700 64MB AGP, SB Live!
Reply 229 of 453, by bjwil1991
Which reminds me. Gotta check my SC-55 to make sure the battery didn't leak as it's been sitting for a long time without power.
Reply 230 of 453, by HandOfFate
Well, my SC-88 Pro battery seems to be fine. I'd like to remove it (it doesn't have it to remember any settings anyway) but I'm not sure how to get it out?
I can move it a little when I put a flat screwdriver under (or above) the battery, but it's difficult to see what I'm doing so I don't want to use too much force. Is there any trick to it? I'd rather avoid taking out the upper board.
Reply 231 of 453, by imi
I didn't even try without taking out the upper board... seems hard to do without.
Reply 232 of 453, by HandOfFate
Yeah, I guess I'll have to take it out then. I always try to avoid any chance of damaging things, but I guess it's unavoidable here 😀
Reply 233 of 453, by Dimitris1980
So,
1. Roland MT32 (old) does not have battery.
2. Roland Sound Canvas SC55 mark I has one, i have replaced it with new.
3. Roland Sound Canvas SC88 (not the pro), i guess it has, i will have to check it.
4. What about Roland CM64 and Yamaha MU50?
- Macintosh LC475, Powerbook 540c, Macintosh Performa 6116CD, Power Macintosh G3 Minitower, Imac G3, Powermac G4 MDD, Powermac G5, Imac Mid 2007
- Cyrix 120
- Amiga 500, Amiga 1200
- Atari 1040 STF
- Roland MT32, CM64, CM500, SC55, SC88, Yamaha MU50
Reply 234 of 453, by keropi
MU50 has a battery but it's soldered AFAIK
CM64 does not have a battery
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 235 of 453, by yawetaG
SC88 has the battery, in a holder (like most Roland gear).
Headless modules (no or minimum buttons on front) intended for use with a computer only usually lack a battery, and generally also lack persistent memory into which to save settings (patches usually are saved in the computer editor).
Reply 236 of 453, by yawetaG
HandOfFate wrote on 2020-07-14, 19:12:
Push back and flip up?
Some holders have a little slide you must move before removing the battery.
Reply 237 of 453, by Dimitris1980
A video for battery replacement on a Roland Sound Canvas SC88 pro.
https://youtu.be/moF9TCZdKoE
- Cyrix 120
- Atari 1040 STF
Reply 238 of 453, by HandOfFate
Having to put a tray on your bed in order to work on stuff. He must be living in a very cramped house.
Thanks for sharing the video. This will help 😀
Reply 239 of 453, by TheGoose81
Is there any real reason to leave the battery installed if only using for Game Music?
Thanks
Mike
