First post, by nikoladd
I'm having a very strange problem with dosbox(0.63). I've searched quite alot for a solution on this and never found one.
I'm having a middle range PC AthlonXP 2100+ 768DDR@333 ATI Radeon9200. Running tunned win2003 as desktop OS. My sistem is pretty fast for anything but high end 3D games.
DOSBox did run pretty well with this system for quite a while at 15000cycles it took no more than 75% cpu(according to sysinternals ProcessExplorer).
I haven't used it in some time and suddenly it crawls so slow that even at 200cycles it takes full 100% CPU.
My suspicion is that either some of my development frameworks(Delphi,NetBeans) or VMWare is messing it up. I had this same problem a year ago before I reinstalled my OS. Now I know for sure that neither MSVC nor .NET framewok are responsible as I don't have MSVC anymore and .NET is installed with clean w2003.
It works so slow that it seems like some vital library used by DosBox has been replaced with debug version.
I've also tried "Graphics performance boost" patch and while there was a very slight improvement it didn't help at all with my problem.
I've also tried disabling every service that could possibly interfere.
It must be something very general as sound and video options have virtually no effect when changed in wide ranges.
I have attached a screenshot of Processexplorer showing dlls and their verions that DOSBox uses on my system. Can anyone please check with his well running sustem what versions are there.
Any help would be greatly appreciated.
