First post, by enrolado
Can any1 help me out..
Im trying to run a program that will connect to USB hardware... but the prog. only runs when under DOS mode (without EMM386.EXE)..
the output message is exactly this:
MSI Diagnostics must run under DOS mode (without EMM386.EXE)!
thanks
Reply 2 of 3, by enrolado
you think this is possible using any linux other dos emulator? or am I screwed?
I need to be able to decode a USB hardware protocol... I was planning on creating a dummy USB logger driver and through dosbox I'd capture whatever was being sent to USB port...
thanks
Reply 3 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
DOSBox doesn't support acces to usb devices.
I doubt dosemu does either.
Maybe Bochs would.
Water flows down the stream
