Reply 20 of 24, by Jo22
You can also try hard disk compression (DoubleSpace/DriveSpace etc)..
That way, I got WfW 3.11 to install on a 16MiB DOM once (that DOM was preinstalled in one of my thin clients before I replacet it with a CF adapter).
Anyway, the original Win95 was about 40MiB in since (remember, it came on 1,44MB floppies, too!).
I remember installing it on old Conner drives somewhen in the 1990s (386 PCs).
Reply 21 of 24, by rmay635703
derSammler wrote on 2020-05-29, 07:07:
rmay635703 wrote on 2020-05-29, 03:18:
Good luck getting *any* software running on that, as you'll have hundreds of missing DLLs. That's just a (nice) proof-of-concept, but not a usable OS.
98lite is perfectly useable but as you add in things (like networking) the OS increases in size, same with directX. I use a 98lite box all the time, never had a missing DLL but did have it demand the 98cd to install things causing bloat.
For those who want networking but want to keep a small size you need to use “other”networking options like you would with Windows 3.1.
Reply 22 of 24, by matcarfer
Seriously […]
Seriously
https://www.litepc.com/98lite.html
http://bednyazhka.narod.ru/Spesial/98-ME-2000 … lite/nano98.htm
Even China Dos union if you have to.
Thanks for the suggestions.
Reply 23 of 24, by henk717
I had the same issue on my t5710 and it was a no-go even on 256mb of storage. By the time I had enough installed for it to run as intended I would be out of storage. Most of these thinclients have 44-pin ide flash modules from apacer so for me buying a $10 2GB module was the better solution.
Reply 24 of 24, by matcarfer
henk717 wrote on 2020-06-02, 01:19:
I already have an ide 44 to sd adapter, but its male, as the motherboard connector, and I cant find a female female 44 ide cable anywhere in my country, and aliexpress is canceling me my orders. All in all, it seems i wont have the cable for a long time.
