Reply 20 of 43, by gdjacobs
It's been a while since I messed with third party DOS mixer utils, but the ESS mixer is SB Pro compatible. Maybe worth looking at some of the options from textfiles?
http://cd.textfiles.com/simtel/simtel0101/sim … nd/00_index.htm
Reply 21 of 43, by Pierre32
Oh well, she's unplugged again for now as I had to get on with some MIDI activity in this box. Thanks for the link though; there will be other test days, and I will try out some stuff then.
In the meantime, I've compiled what I've learned into a PDF. It's incomplete, but hopefully it helps someone in the future. Maybe someone will even find it, then come back and tell me everything I got wrong so I can update it!
EDIT: PDF now attached to first post
Reply 22 of 43, by Pierre32
The card remains uninstalled for now, but I can't help googling things. I was browsing ebay for other ES688 cards, and noticed that some of them have an additional chip that mine does not: The ES968. Then the penny dropped: That's the message I've seen on startup if I have Autoexec initialising the card with ESSCONFIG. ES968 not found.
I searched for info on that chip and found: https://gitlab.freedesktop.org/seanpaul/dpu-s … c98b0106c42c70a
The ESS ES968 chip is nothing more then a PnP companion for a non-PnP audio chip. It was paired with non-PnP ESS' chips: ES688 and ES1688.
Which suggests that all the ESS drivers I've found are intended for PnP cards? And affirms my belief that there is still a long lost version of the drivers out there somewhere. Not immediately helpful, but another crumb of data.
Reply 23 of 43, by jpb123@email.com
Pierre32 wrote on 2020-06-06, 02:53:
The card remains uninstalled for now, but I can't help googling things. I was browsing ebay for other ES688 cards, and noticed t […]
I was about to ditch one of those cards in the late nineties. I was making a PC from junk,as the power source of my old ACER had gone burst and replacing it was expensive. I bought a whole pc with motherboard and power source from a friend for the price of a beer bottle and I began searching for an audio card to record the voice of my new born daughter.
So, I went to a PCshop and asked for an ISA sound card, cause my motherboard did not accept PCI.
At first sight they told me they did not have one (as it was already old stuff at the time) but then a technician remembered they had one somewhere at the workshop.
They sold it to me with no guarantee as (I realised later) they had not been able to make it work. It came in a Yamaha branded open box and I began to search for a driver after plugging it into the motherboard as I was in no condition of writing a driver by myself.
Luckily the bios or some other software told me it was no yamaha but an ESS ES688 sound card. I do not remember how I managed to know where to plug the card for the beginning but I do remember the driver that was in the manufacturer web page did not make it work.
A week passed with me searching in internet only to find myriads of people complaining for that particular card not working for their PCs. And when I was about to ditch the card I found the driver under a Polish web page. It was an executable for DOS named Shark.exe, that´s all I can remember. It worked fine for the next six years, after what I ditched the whole PC cause it was not upgradable anymore and it had become to slow for modern world internet.
Reply 24 of 43, by Pierre32
Thanks for sharing that! It's comforting to know that I'm not the only living soul who hit the jackpot with this exception-to-the-rule Audiodrive. I will probably be spending some late nights trawling the Polish web for Sharks now.
Reply 25 of 43, by cyclone3d
Pierre32 wrote on 2020-06-06, 04:03:
I bet that Shark.exe was drivers for a Shark Multimedia branded sound card.
Looking at their archived page, it looks like they used ESS chips.. but the archived drivers only go back to ES1688.
http://web.archive.org/web/19970205084353/htt … ://sharkmm.com/
Have you tried the generic drivers directly from the ESS archived site?
http://web.archive.org/web/19970626173050/htt … es/intro_ud.htm
Seeing as how the DOS / Windows 3.1 is the same driver set from everything from 488 up to 1888, maybe the Shark Mako driver would work as it is for the 1688.
Edit:
What about the Edison Gold 16 driver set? This card doesn't have the ES968 AND the ESSCFG is from 1993 while the others above are from 1995.
http://vogonsdrivers.com/getfile.php?fileid=1461&menustate=0
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 26 of 43, by appiah4
That just means you do not need ESSCFG at all, yout card is non-PnP and will work right away if you set the matching BLASTER variable for the jumper settings. ESSCFG will only help if your card is PnP. ESSVOL mixer will still work though.
I have an Edison Gold-16 which also lacks an ES968 in my 386SX. It has no jumpers for IRQ and DMA and defaults to IRQ7 and DMA1 and runs at that unless I run ESSCFG to change it on a per boot basis. The ESSCFG in the Edison Gold-16 drivers I uploaded to Vogons Drivers and was linked above works with this card. I will check the boot config and post back.
Reply 28 of 43, by appiah4
derSammler wrote on 2020-06-06, 08:04:
I don't think ESSVOL will do anything, as the ES688 has no hardware volume control.
I will check this as well.
Reply 29 of 43, by Rawit
https://www.high-voltage.cz/2018/obrazem-isa-zvukove-karty/
There is a collection of soundcard images there, one being the same design as you have. Perhaps you can copy the jumper settings from that one and see how it fares.
About not supported in DOS; that is very unlikely with this card. The laptops mentioned in that thread have the chip hooked up on PCMCIA bus without DMA.
YouTube
Reply 30 of 43, by Pierre32
Lots of great input, cheers 😀
cyclone3d wrote on 2020-06-06, 05:23:
I bet that Shark.exe was drivers for a Shark Multimedia branded sound card. […]
I've been through the old ESS archives, yeah. Good shout on Shark Multimedia, that's an interesting lead! I had a dig through, and it looks like their Mako 1 was an ES688 card. Their version of ESSCFG actually recognises my 688 (refer pic 01) but looking at the deeper options (pic 02) it specifically says no MPU options available on the 688. And no sign of any TSRs in this driver pack.
appiah4 wrote on 2020-06-06, 07:59:
I've got this pack. ESSCFG doesn't like the card, but I guess that's a moot point as you say. ENMPU initialises without any complaints (pic 03) - but the MPU is still not visible to any other software such as games or SoftMPU. (FWIW, P330 had also been added to SET BLASTER params). Interested to see your boot config.
Rawit wrote on 2020-06-06, 09:52:
Nice find. Looks like I've landed on the same jumper config already.
    170.71 KiB
    191.73 KiB
    200.85 KiB
Reply 31 of 43, by appiah4
OK I checked out my 386SX. It has this card installed, jumpered as shown in photo:
Here is the system configuration for DOS:
Here is the ESSCFG output:
As you can see it responds to the ESSCFG.EXE from the Edison Gold-16 pack I mentioned above. The card is jumpered to A220, and the Joystick/IDE are also jumper controlled but I7 and D1 can be changed at boot using ESSCFG. If you do not want to load ESSCFG at boot, it automatically configures as A220 I7 D1 regardless.
It is also completely responsive and functional with ESSVOL:
Also, I can confirm that the ENMPU TSR is not compatible with SOFTMPU, apparently. I hadn't noticed because I use a MIDI Interface Card in this system at 330 instead, but I can use devices that do not need intelligent mode on port 300 with this card.
For more information about setting up this card with ESSCFG you may want to check out thispost and this post I made to another user in another argument..
Reply 33 of 43, by gdjacobs
appiah4 wrote on 2020-06-06, 14:24:
I wonder if SoftMPU could be extended to provide the MPU401 interface directly.
Reply 34 of 43, by Pierre32
Fresh eyes and the chance to bounce things off people have resulted in a little more progress on the documentation of this card. No MPU yet, but here's a thing: ESSCFG in the Edison Gold pack does recognise this card. Why didn't it before? Conflicts? Operator error? It is a mystery. But not important now.
What I did notice today, now running the Edison files, is that ESSCFG was reading a different IRQ from the card than the one I had set in Autoexec. Puzzled, I removed one of my as-yet-unidentified jumpers and ran it again. And boom, new IRQ. It turns out that two jumpers I thought were not related to each other (thanks to the janky labelling) are actually a pair, and now I know what they do. So that's all of Bank 1 accounted for.
I also spotted some jumpers I hadn't noticed before, which is pretty funny. Nestled between the two huge blue caps and the audio output, I assumed these were for line/amp switching and that turned out to be correct.
In the sequence of jumper numbers, JP6 is still missing. That's probably the MPU enable they left off at the factory <.<
(Full PDF now attached to first post)
Reply 35 of 43, by perhenden
Thanks,Pierre32, this was a huge help 😀
I'm hoping to figure out how to enable the IDE-CDROM on this card.
Regarding the block 2 jumpers, it makes sense as you say, that they control CDROM-configuration.
On my card, which looks identical , but has a sticker underneath saying "Ultra products, 12/1995", as well as empty solder pads in place of LS-212, there are labels near the CD-ROM headers.
Perhaps that's also the case with your card, I couldn't tell from the picture.
These labels say, going from card rear to card front (right to left), Sony, Mitsumi, Panasonic, and Secondary IDE.
My card has all the jumpers in block 2 set to the lower position (touching the white line), like yours.
According to Re: Where to find Jumper settings for Audio Drive ES688, which lists jumper settings for another ES688 with the same four CDROM-headers, there is a large number of potential settings to configure by jumpers.
On this card there are few jumpers, compared to that other ES688-card mentioned. We could perhaps deduce what the jumpers must represent, by considering which configuration options are required as a bare minimum.
There is no selection of IDE base address, it's always 170h, as that is indicated by the label "Secondary IDE", so that accounts for one of the "missing" jumpers.
We know that CDROM-type must be one of them. I see Sony & Mitsumi grouped together as the same setting on other cards, so at least three values to choose from are required here.
Non-IDE io base address should be one of the jumpers, given that is unpractical to have no choice here. You would need at least two values to choose between. I see some other cards given the selection of either 320 or 340.
It seems that non-IDE CDROM requires DRQ/DACK, which should have the same value, and is a DMA address (1/2/3), so that takes three values.
An IRQ is perhaps required? Or would it be possible to do without by polling the io ports? I'm guessing required.
The other card used two three-pin jumpers for non-IDE IRQ, and one for IDE. That brings us down to zero remaining jumpers.
My guess then is (using letters as I can't infer which jumpers are which):
2-pin A: IDE IRQ (14/15)
2-pin B: non-IDE io base address (320/340)
3-pin C: non-IDE DRQ/DACK (1/2/3)
3-pin D: non-IDE IRQ (9/10/11)
3-pin E: CD-ROM type (Mitsumi & Sony, Panasonic, IDE)
Hope this can be of use, perhaps for others to build upon.
I don't know how to initialize the CDROM-controller, there is perhaps a driver/sys-file I can load from config.sys?
Reply 36 of 43, by Pierre32
Glad this thread has helped someone else, and that's some great additional input 😀 I've just scoured my photos and found one that shows the CD header labelling:
120.8 KiB
Left to right:
I7 - Secondary IDE
I6 - Panasonic
I5 - Mitsumi
I4 - Sony
My card is stowed away at the moment but it will find its way on to the test bench again, because I can never let unanswered questions go. I've never tried to use the CD connectors but it would be very satisfying to at least get the IDE working with the help of the clues you've provided. And recently, Deksor has scraped soundcard-drivers.com and uploaded the lot to archive.org, so there might be some more resources to wade through:
Link Repository for Vintage PC Driver\Documentation Archives, FTPs, Websites
[edit] Curious about the lack of LS-212 chip on your card. How does it handle FM?
Reply 37 of 43, by pan069
OK I checked out my 386SX. It has this card installed, jumpered as shown in photo: […]
Apologies to quote an old(er) post, but, are you using the IDE CDROM connection on the sound card or another secondary IDE? I have been trying to get the CDROM interface to work my my ESS based sound card and so far have failed. I thought, maybe you could same your CDROM driver the VIDECDD.SYS one?
ESS Edison Gold 16 IDE setup (help me troubleshoot)
Reply 39 of 43, by Panties
Good Day Appiah4 & ESS owners and Vogons users...,
Sorry to necro this old thread...
I just recently bought this card for a very fairly cheap price,.... so I getting this card for a Pentium 166 MMX (My lowest Retro computer in my home.. I do not own a 386 nor 486..).
I saw your card, and it is pretty much identical to what I have... (yours is "Gold-16 Rev 3.2B" written on your PCB... while mine is "SX_16 Rev 2.1").
I have attached the picture (Sorry for low quality).
I been vogons/googling research about this card, before I even post the question here.
So bear with me, if my question are "too silly"...
a. Base on your Picture, JP2 - "CLOSE ENABLE SOFTWAVE ADDRESS FOR ES1688 CHIP ONLY" . What that jumper does? what does it do?
(Because mine, it is stated "EN" and that's all. Don't know what that does...)
b. So, Since my board, is quite identical as yours, which driver do you use? I want to try to same drivers as yours, and test it.. 😀
Appreciate your feedback on this....
