First post, by Demetrio
Hi, I have an old pc from the mid '90s, borrowed from a friend of my father, in which I've installed Damn Small Linux and MS-DOS 6.22 in dual boot.
It works well; I can play games, go on the Internet, code...
I can also play mp3s, both in DOS and in DSL, but I noticed that they are played slightly slower.
I don't know why, maybe the CPU cannot play these files perfectly, I really don't know.
All the mp3s have 320 kb/s bitrate and 44100 Hz sample rate.
PC has:
  • CPU: AMD K5 90 MHz
  • RAM: 32 MB
  • Audio card: CMI8330
Thanks in advance.
Reply 1 of 25, by darry
Some ultra cheap CMI8330 based cards do not have an onboard oscillator and use a clock signal provided by the motherboard, which may not be the right value for proper playback speed .
EDIT : See Re: Sound Blaster 16 Clones
Maybe adjusting your ISA BUS clock speed in BIOS will help .
Reply 2 of 25, by Demetrio
If I reduce mp3 bitrate, there's a chance that the playback speed will improve?
Reply 3 of 25, by rmay635703
Demetrio wrote on 2020-06-02, 22:43:
Improve how?
Audio accuracy, probably not
Audio loading time, skipping and buffering = better
Reply 4 of 25, by Demetrio
I didn't see the edit so I asked (I'm not an expert).
I will try changing the clock speed in BIOS.
Thanks for the help.
Reply 5 of 25, by darry
If CPU speed is insufficient, audio playback will skip, not slow down .
The slow playback speed is likely due to the card receiving an inappropriate clock signal, so lowering bitrate will not help at all .
Test it with an uncompressed wav file, you should have the same issue .
To fix this, you would probably need to modify the card by adding a proper clock oscillator (there used to be instructions on the Internet about how to do this, but I cannot locate them) . As mentioned before, if you are lucky, maybe changing the ISA bus clock speed in your BIOS will help (if you have such an option) .
Reply 6 of 25, by derSammler
darry wrote on 2020-06-02, 22:50:
Wrong. It will slow down with most MP3 decoders. Only a few skip actually, as they clear the buffer during playback (like Winamp e.g. does).
There's no way for a K5 with 90 MHz to play 320kbps MP3s. You need Pentium 75 speed for 128kbps joint stereo already.
Reply 7 of 25, by matze79
K5 90Mhz is faster then P75..
Reply 8 of 25, by derSammler
No, it's not. MP3 uses floating point for decoding at which the K5 sucks. Also, you'd need that speed for a 128kbps joint stereo file, but he is trying to play 320kbps simple stereo files that need about 3 times as much horse power.
Reply 9 of 25, by darry
derSammler wrote on 2020-06-03, 11:10:
That has not been my experience when attempting playback back in the day on a 486 with the multiple Windows players I tried at the time (among which Winplay3 and Winamp) . All of them skipped (presumably when the buffer underflowed) . I would imagine that slow playback could happen if the player has trouble even feeding rhe sound card fast enough from its buffer (if it has one), because the PC is really much too slow, but that would still give at least glitchy audio as samples would certainly be dropped unevenly, which is not what the OP described . Please provide examples of MP3 players that provide slower glitch-free playback on underpowered machines (I am of course not referring to the ones that let you adjust the playback speed intentionally, that is different).
Anyway, I suggested playing back a wave file to be sure it was a sound card clock issue and not related to MP3 decoding capability.
Reply 10 of 25, by Demetrio
I remembered that the CMI8330 on the pc was an ISA card but I found out that is connected directly on the motherboard.
By the way, I will try playing a wav and see what happens.
Reply 11 of 25, by Garrett W
Yeah, pretty sure you need a faster CPU. Try 128kbps files and see how they perform.
Reply 13 of 25, by Demetrio
I played a wav in DSL: it seems to be better, maybe tiny slower but it is barely noticeable.
Reply 14 of 25, by zyga64
You can try older Winamp (2.x line) it has mp3 decoder which can be configured for older processors
Image is taken from this thread Lowest CPU to play MP3s?
8088@8 /640k /Genoa CGA /ALS100
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
I5 3470s /8G /GTX750Ti /HDA
Reply 15 of 25, by darry
zyga64 wrote on 2020-06-04, 06:27:
You can try older Winamp (2.x line) it has mp3 decoder which can be configured for older processors https://i.imgur.com/zkqNisq. […]
Winplay3 is also worth a shot. It is very old and optimised for the machines of its era .
But if that wav file played slower than normal, it is still strange . Was the wav file the same as song as one of the MP3s you tried? It would make the comparison easier .
Reply 16 of 25, by Demetrio
darry wrote on 2020-06-04, 06:33:
Yes, it was.
The wav has the same sample rate of the mp3 and a bitrate of 1411 kb/s.
Like the mp3s, I tested it by playing it with the same song on my phone at the same time: it seemed that it was tiny slower but maybe I perceived wrong.
I didn't tested a lot so I can be wrong.
Reply 17 of 25, by Demetrio
I retested the wav: it is slower.
I played together the song slightly before on the pc and shortly after on my phone: the phone exceeded the pc.
Reply 18 of 25, by pii_legacy
The first reply of this thread told you exactly the problem so why waste so much time testing it? If a 68000 can play an MP3 (as long as it's the only thing it's doing), your CPU is capable.
Reply 19 of 25, by Demetrio
pii_legacy wrote on 2020-06-04, 18:24:
Other posts said that it could be the CPU so I wanted to be sure.
The CMI8330 is connected directly to the motherboard so I don't know how to fix this; maybe I will buy another audio card.
