First post, by MiniMax
Rank Moderator
Moderator
Anyone else seen this problem here at VOGONS?
I usually go directly to the 'since last visit' page, click my way through the new posts. After reading a thread, I hit the back-button in my browser, and very often I get a
You cannot make another search so soon after your last; please try again in a short while.
message instead of returning to the 'since last visit' page.
Is this a new feature of the forum-software?
Any chance of having the 'soon'ess lowered a bit?
This is with Firefox 1.5.0.4.
_________________
Reply 1 of 4, by Lofty
Yep. Only a minor annoyance though.
Reply 2 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
the search flood thing is 15 seconds.
If it's really anoying I could see if I can disable it for the newposts check though
Water flows down the stream
Reply 3 of 4, by MiniMax
Rank Moderator
Moderator
I don't think the root problem is the "search flood thing". When I check the HTTP-headers (using the Web Developer plug-in for Firefox), I see the following:
Response Headers - http://www.vogons.org/search.php?search_id=newposts
Proxy-Connection: Keep-Alive
Date: Fri, 23 Jun 2006 16:29:21 GMT
Cache-Control: private, pre-check=0, post-check=0, max-age=0
Expires: 0
Pragma: no-cache
Vary: Accept-Encoding
X-Powered-By: PHP/4.4.2
Transfer-Encoding: chunked
Content-Type: text/html; charset=UTF-8
200 OK
I think it is the Expires: 0 (expire immediately) combined with max-age=0 and Pragma: no-cache that causes the browser to re-post the search URL even when all I do is to use the back-button in the browser.
(while I investigated this, I found these two cache-testers: http://www.ircache.net/cgi-bin/cacheability.py, http://www.web-caching.com/cacheability.html)
Perhaps it would be possible to set the expire time to something like 60 seconds for all searches?
_________________
Reply 4 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
All phpbb2 based boards sets these headers.
