First post, by ildonaldo
I’ve just got my “new” L.I.S. 2 indicator* display & fan controller from around 2004.
The display came boxed and “as new”, but unfortunately the software-CD got lost over the time.
Thanks to evasive I've found some generic drivers,
but if you’ve got the latest retail USB-drivers and software for this display, please send it to me!
See here some pictures of the “unpacking” ...
50.27 KiB
Box Front - VL System, L.I.S. indicator "Blue Eye"
GPL-2.0-or-later
62.8 KiB
Box Rear - VL System, L.I.S. indicator "Blue Eye"
GPL-2.0-or-later
67.44 KiB
Box content - VL System, L.I.S. indicator "Blue Eye"
GPL-2.0-or-later
40.96 KiB
Display Front - VL System, L.I.S. indicator "Blue Eye"
GPL-2.0-or-later
57.48 KiB
Display Rear - VL System, L.I.S. indicator "Blue Eye"
GPL-2.0-or-later
The display appears to be new/unused (even the protective foil is still in place) and does not show any installation marks.
I intend to install the display & fan controller in my PC #3 (see sig), because it is in period and comes with a matching silver Lian Li case.
… to be continued 😀
* L.I.S. = Lost In Space (IMHO a bit strange name for a display)
Building my own PCs since 1991 - for my retro builds it's "no CF-disks, no Floppy emulators, no modern cases etc.", only the real and authentic stuff whenever possible.
Reply 2 of 10, by Doornkaat
You already found that in the other thread as I see. Oh well, I'll leave it anyway in case the other source expires.
This might be the driver though. Please report back if it works.
    LIS_USB_Setup.zip
    1.5 MiB
    53 downloads
Reply 4 of 10, by ildonaldo
I've now started to install the device with a temporary wiring in #3 😀
53.44 KiB
L.I.S. 2 indicator with temporary wiring
GPL-2.0-or-later
... to be continued 😉
Reply 7 of 10, by ildonaldo
It's alive!!! and raving 😉
If anyone can submit me the right software-code for this tool "mutimedia control center" for 'DEGREE CELSIUS' (U+2103???) it would be great.
many thanks, ildonaldo
50.29 KiB
GPL-2.0-or-later
31.67 KiB
GPL-2.0-or-later
Reply 9 of 10, by ildonaldo
Matches the 2003 case perfectly and it even manages the three fans for this case (dependent of the MoBo-Sensors).
Reply 10 of 10, by ildonaldo
... and please let me know how to set a longer delay than 10 sec. for the differen states in this software!
