Reply 20 of 71, by Swiego
I’m not sure why I enjoy this so, but in my ongoing journey to know and love the Millennium, I have finally found the 12MB WRAM module! It’s Compaq branded, cool and largely useless. I love it!
Incidentally in searching for it I found that there were Compaq and HP kits as well as the kit direct from Matrox and they all have different part numbers and varying availability depending on where in the world you are.
Here is the box, a Millennium II with the upgrade installed, and the 4MB upgrade for comparison.
So the key findings:
1. It’s cool
2. When connected to a 4Mb card, there is indeed 16MB seen by Matrox utility in Windows 98. As expected, there is no resolution/color depth advantage nor performance advantage (Winstone/Winbench in W98Se and DOS) that I could discern when compared to the 12MB configuration.
3. I had a 8MB card and thought... what happens if I add the 12MB WRAM to it?! 20MB?! Well for the zero people who’ve always wondered about this... The card works fine, Matrox reports 16MB (aww) and there again is no performance difference vs the “sanctioned” 16MB configuration.
I’m not sure where I go from here, but I’m gonna continue living the 1920x1200x24bpp dream on a card that incidentally works perfectly on a 486.
