First post, by niki_iv
Seems like I am having problems with two Slo1 Mobos
One is BioStar M6TZA - this one is curious .. it boots, it detects the disks, then it shows a popup with the CPU temp and voltage and fan speed, then it goes to the usual screen where it displays the BIOS data and there it freezes on the disk detectoion. It has detected the disks fine a moment ago.. If I go to BIOS - IDE HARD DISK detection it freezes
The other one is Abit AH6, same thing but it doesn't have this initial screen where it detects the drive. Same freeze in the IDE HARD disk detection
Is this a known problem?
