Reply 20 of 109, by dr.zeissler
Only the first 6200-AGP Models with active Cooling and full-PCB have 128BIT Memory-Interface. I am satisfied with 64Bit, because these cards are fast enough for my purpose, but I can't distinguish how performant these LE/SE/TC PCIe variants are ? I do own three AGP Version, they are all really good (beside the DVI-Output in small resolutions https://forums.geforce.com/default/topic/1026 … ange-this-thx-/ )
But I need the exact same performance of the AGP-Cards for the PCIe-Cards. Afaik there are no "normal" 64Bit NV44a PCIe Versions of the 6200 available. So I think the best way to go is the TC256MB/512MB Version.
It has the same 256MB DDR2 Ram with 64Bit onboard and can take up another 256MB to 512MB from the main memory. I hope I can deactivate that in the driver because 256MB dedicated memory is enough for me.
Doc
