First post, by tomexplodes
I can of course run the game in software rendering, but it's slow. I'm hoping there's a workaround of some kind to get it to run without glitches in hardware mode.
AMD Athlon 1.3 ghz
ATI Radeon 7000 64 mb
256 mb ram
98SE with Unofficial SP3
I've made it ALMOST work with the 1.02 patch, in spite of not having an Nvidia card. In Riva 128 mode, the text is garbled and the background is cut into chunks. In TNT mode, it's ALMOST perfect except I've noticed that Barrett's beard is missing in battles, so I expect other graphical oddities exist.
I tried to install Aali's opengl fix 0.8.1b, but it seems to be for a later Windows version. I also tried the slightly older 0.7.11 build, but that just makes my graphics go away in game.
Anyone who's made this work with an ATI card, please help. I understand that there are a million other options for playing FF7 these days, but the hardware accelerated version with that gorgeous Yamaha midi... that's how I played it in my formative years, that's how I love it. Help me Vogon-Wan Kenobi, you're my only hope!
1.) MS-DOS 6.22, Pentium-S 90mhz, 32mb RAM, S3 Trio64, Vibra 16
2.) Windows 98 SE, AMD Athlon XP 3000+ 2.1ghz, 512mb RAM, Geforce 4 TI 4200 128mb, Sound Blaster Live! Value
Reply 1 of 13, by infiniteclouds
I would recommend using an era appropriate ATI or using nVidia -- they have always (and still) seem to have better backwards compatibility than ATI.
Reply 2 of 13, by bloodem
Unfortunatly, I don’t think there’s an option to play it with an ATI card. Just get a cheap GeForce 2 MX and you’re good to go.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 3 of 13, by Wolfus
What about Glide? I am pretty sure I played it accelerated with V2.
Reply 4 of 13, by leileilol
ff7 didn't use glide
Reply 5 of 13, by Wolfus
It could be FF8 then. But I really remember playing FF7 accelerated in black-bordered fullscreen...
Reply 6 of 13, by infiniteclouds
The FF7 demo supported glide -- that was all.
Reply 7 of 13, by Parni
Get your self a Voodoo 😉
Reply 8 of 13, by bloodem
Yeah, get yourself an expensive video card (such as a Voodoo 2 / 3), so you can play a game that runs perfectly on a $5 video card 😀
Reply 9 of 13, by Joseph_Joestar
If I'm not mistaken, FFVII needed support for palleted textures, and Ati cards simply don't have that.
Any Nvidia card from that era should work fine though, so I second the GeForce2 MX recommendation.
Reply 10 of 13, by cyclone3d
I still have the trapezoid boxed version of FFVII that I pre-ordered. The box has the 3dfx logo on it. I played it on whatever 3dfx card I had at the time it was released.
Here is the text from the FF7ReadMe.txt about original video card support:
VIDEO CARDS
Supported 3D Accelerator Video Cards
Final Fantasy VII currently supports 3D accelerator video cards that
pass the criteria contained in the FF7 Configuration graphic card test.
At release time, the game supports the cards that contain any of the
following chipsets:
3Dfx Voodoo
3Dfx Voodoo2
3Dfx Voodoo Rush
3Dlabs Permedia2
ATI Rage Pro
Intel I740
In addition, the game will support the following chipsets when they
ship later this year:
Matrox G200
NEC PowerVR2
The D3D patch did not come out till later.
Edit:
If you want to play it well without an officially supported video card, then you probably want to get the unofficial patch stuff and set it up in XP. I remember it being a super pain to get working, but once you do get it working it works just fine for the most part.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 11 of 13, by Wolfus
Thank you. I was thinking my memory is playing tricks on me.
Reply 12 of 13, by Gamecollector
FF7 is d3d + software. The glide API isn't supported in this game.
The unpatched version of FF7 needs palettized textures for the d3d mode. The patch "workarounds" this requirement and the game works with all d3d videocards.
Reply 13 of 13, by tomexplodes
I put my old Geforce 4 MX 440 in my 98 machine and poof, works out of the box. Thanks for the help, everyone!
