Reply 40 of 268, by kalohimal
Revolter wrote on 2020-06-14, 14:01:UPD.: Can confirm CPUSPD also works fine in WinME 😀
Just noticed this. That's great news! Thank you very much for helping!
Slow down your CPU with CPUSPD for DOS retro gaming.
@johnnycontrario and anyone who has VIA C3 and is willing to help out with the testing:
I've added cpu detection and multiplier functionalities for VIA C3, with support for Samuel, Samuel 2, Erza, Erza-T, and Nehemiah. The code is completely untested though (as I do not have any C3 cpus), and I expect there will be tons of bugs... 😁
Please help me test the following:
1. Cpu detection - issue command: Cpuspd d i
2. Show current multiplier - issue command: Cpuspd d m
3. Set multiplier - issue command: Cpuspd d i m5.0 i (please substitute multiplier as you wish)
4. Cache and throttle - issue command: Cpuspd i cd t4 i (no reasons why they won't work but just in case)
Please note that for 3 & 4 the commands have 2 "i"s, first one to show the initial frequency and second one to show the frequency after multiplier change.
Please report back the results, best if you could attached a screenshot. Thank you very much for your help!
kalohimal wrote on 2020-06-16, 15:08:@johnnycontrario and anyone who has VIA C3 and is willing to help out with the testing: […]
4. Cache and throttle - issue command: Cpuspd i cd t4 i (no reasons why they won't work but just in case)Please report back the results, best if you could attached a screenshot. Thank you very much for your help!
CPUSPD1.3-alpha1.zip
I have some time today for retro shenanigans. I should be able to post some results by tomorrow.
johnnycontrario wrote on 2020-06-16, 15:27:I have some time today for retro shenanigans. I should be able to post some results by tomorrow.
Thanks!
4. Cache and throttle - issue command: Cpuspd i cd t4 i (no reasons why they won't work but just in case)Please note that for 3 & 4 the commands have 2 "i"s, first one to show the initial frequency and second one to show the frequency after multiplier change.
OK, here are my results. I do not have a great way to capture screenshots, so after testing, I redid the tests redirecting cpuspd output to text files. I tested in Windows 98 by restarting in MS-DOS mode. The DOOM realticks are measured using Phil's Computer Lab Dosbench utility: "Doom max details"
CPUSPEED version 1.3 alpha1. This program is freeware.Written by David Chee Y. Wong, Johor Bahru, Malaysia.DPMI version: 0.90 flags: 01VIA Ezra ID(6,7,A)CPU frequency is 797MHz (TSC)CPUID.1 ebx=00000000 ecx=00000000 ecx=00803035 flag=0007
CPUSPEED version 1.3 alpha1. This program is freeware.Written by David Chee Y. Wong, Johor Bahru, Malaysia.DPMI version: 0.90 flags: 01Current multiplier: 6.0
CPUSPEED version 1.3 alpha1. This program is freeware.Written by David Chee Y. Wong, Johor Bahru, Malaysia.DPMI version: 0.90 flags: 01VIA Ezra ID(6,7,A)CPU frequency is 797MHz (TSC)CPUID.1 ebx=00000000 ecx=00000000 ecx=00803035 flag=0007Entering: do_longhaulMultiplier 0b, bcr2 = c4001002Writing msr bcr2 = c5881002Halting CPU...Done.Current multiplier: 5.0VIA Ezra ID(6,7,A)CPU frequency is 664MHz (TSC)CPUID.1 ebx=00000000 ecx=00000000 ecx=00803035 flag=0007
Command: resultFull Speed: 719 realtickscpuspd d i m5.0 i: 770 realtickscpuspd d i m4.0 i: 852 realtickscpuspd d i m3.0 i: 1011 realticks
CPUSPEED version 1.3 alpha1. This program is freeware.Written by David Chee Y. Wong, Johor Bahru, Malaysia.VIA Ezra ID(6,7,A)CPU frequency is 797MHz (TSC)Cache is offNo ACPI, please check BIOS settings.VIA Ezra ID(6,7,A)CPU frequency is 797MHz (TSC)
Command: resultsetmul 4 l1d l2d: 8601 realtickscpuspd i cd m4 i: 8634 realticks
@johnnycontrario
Thanks for the excellent efforts! I'm really surprise to see that it works the first time, wow!
Regarding ACPI, do you have any options in the BIOS to enable it? I saw some date codes on Samuel 2 and Erza and they are at or after year 2002, so ACPI should already be available. Perhaps the board manufacturer had skimmed on the BIOS for cost reduction? This also got me thinking whether I should implement something like Throttle, using database to support older and/or non ACPI boards... It's a lot of work though, as PCI device detection will be needed.
Overall I'm real happy about the results, really appreciate your help. Now we need to find more folks to test out the Samuel 2 and Ezra-T portion...
kalohimal wrote on 2020-06-18, 01:39:Regarding ACPI, do you have any options in the BIOS to enable it? I saw some date codes on Samuel 2 and Erza and they are at or after year 2002, so ACPI should already be available. Perhaps the board manufacturer had skimmed on the BIOS for cost reduction?
I could not find any ACPI related options in the BIOS. My machine was made by a company that sells Point of Sale equipment, so I'm sure energy efficiency wasn't a priority. There are other things on this board that weren't implemented, like temperature sensors. I'll try again if I can get a custom BIOS working on it.
kalohimal wrote on 2020-06-18, 01:39:This also got me thinking whether I should implement something like Throttle, using database to support older and/or non ACPI boards... It's a lot of work though, as PCI device detection will be needed.
This may be a long shot: Throttle's source is open, but I don't see a formal license anywhere. Rather than reinventing the wheel, maybe you can get Jeff's permission to use some of his work in your project.
Good works... keep it up. I from Johor Malaysia too.
Your project spice me with idea building my a ultimate retro PC..
Hopefully these hardware works
Duo Core E2160
512mb DDR (lower it frrom 2G to 512mb for Win98)
GF8500??
Umm....hopefully it works.
johnnycontrario wrote on 2020-06-18, 04:12:This may be a long shot: Throttle's source is open, but I don't see a formal license anywhere. Rather than reinventing the wheel, maybe you can get Jeff's permission to use some of his work in your project.
If I were to do it, probably won't just copy his work, but will definitely use it as reference. It's about a week of coding & testing needed I guess, and looks like it will be fun. Practically though I don't think a lot of people will be needing it, especially judging from the lackluster response to this utility 🤣.
Oh one more thing, could you try it on Win98 DOS box please? Just like to see any issues in protected mode.
simworld wrote on 2020-06-18, 05:53:Good works... keep it up. I from Johor Malaysia too. […]
Duo Core E2160
GF8500??Umm....hopefully it works.
Glad to hear from a fellow Malaysian. Which motherboard are you planning to use? If you're planning to triple boot DOS/Win98/XP, boards with i815 and earlier chipset will be the best. Oh and I think GF8500 has no Win98 drivers too.
kalohimal wrote on 2020-06-18, 06:01:johnnycontrario wrote on 2020-06-18, 04:12:This may be a long shot: Throttle's source is open, but I don't see a formal license anywhere. Rather than reinventing the wheel, maybe you can get Jeff's permission to use some of his work in your project.
I did happen to play with it in a Win98 DOS box, and the cache disabling and multiplier setting worked properly. HWiNFO reports the new clock speed, and disabling cache noticeably affects performance. I disabled cache and set the multiplier to the lowest possible value: Windows 98 looked like it was running on a slow 486.
Perhaps an improvement to Throttle would be to put the database in a configuration file. This way the program does not have to be recompiled to add or remove support for a particular chipset. Adding switches to force a particular chipset is another idea.
Ok noted with thanks. Currently I'm still ironing the C3 bugs, as in this thread. Your suggestion is noted, I'll consider implementing it when I could find more time.
CPUSPD 1.3 beta2 with some bugs fixes for C3 is now ready. Also added max/min multiplier display. Please download it for testing from the above post.
@johnnycontrario
Sorry to trouble you again. When you could find time, would you please help me try this in pure DOS and Win98 DOS box?
cpuspd i m4.0 i
cpuspd i
There seems to be a problem when "i" is issued right after multiplier is changed, in that it won't be able to obtain the cpu frequency correctly. I would like to find out whether this is limited to Nehemiah or Ezra also has this issue as well.
Thank you very much.
kalohimal wrote on 2020-06-18, 17:10:@johnnycontrario […]
@johnnycontrario
cpuspd i m4.0 i
cpuspd iThere seems to be a problem when "i" is issued right after multiplier is changed, in that it won't be able to obtain the cpu frequency correctly. I would like to find out whether this is limited to Nehemiah or Ezra also has this issue as well.
Sure. I'll post results tonight.
Why is this being developed given setmul already exists and is good?
kolderman wrote on 2020-06-18, 19:57:Why is this being developed given setmul already exists and is good?
The reasons are listed in the
"Advantage of CPUSPD over older utilities like Throttle and Setmul, and software solution like slowdown:"
section in the 1st post:
CpuSpd - A Hardware Based CPU Speed Control Utility for DOS/Win9X Retro Gaming
(To name a few: SetMul has no throttling support and does not include support for e.g. P4 and Core2)
Hi, it's because of several things. When I started the project it was aimed at P4 and Core 2 CPUs, with the ability to not only set cache and multiplier but aslo throttling, both in pure DOS and Win98 DOS box. And because I use Yamaha YMF744 whose dsdma needs EMS, it is desirable to have it working in protected mode as well. AMD CPUs were later added, along with other Intel CPUs. Recently there were request to include VIA C3, my initial reply was it's overlapping with Setmul, but later thought ok why not since it could be fun. So there you go... 😀
Edit: oh I forgot to mention it allows the user to set the CPU voltage too. I've been to some HTPC forums and this is important to them as they seek to run the CPU fanless in low power.
@johnnycontrario
cpuspd i m4.0 i
Under pure DOS, I got the following output:
COMMAND: cpuspd i m4.0 iCPUSPEED version 1.3 beta2. This program is freeware.Written by David Chee Y. Wong, Johor Bahru, Malaysia.VIA Ezra ID(6,7,A)CPU frequency is 797MHz (TSC)Current multiplier: 4.0 (min 3.0, max 12.0)VIA Ezra ID(6,7,A)CPU frequency is 531MHz (TSC)COMMAND: cpuspd iCPUSPEED version 1.3 beta2. This program is freeware.Written by David Chee Y. Wong, Johor Bahru, Malaysia.VIA Ezra ID(6,7,A)CPU frequency is 531MHz (TSC)
Setmul reports 4.0x, 533MHz.
In Windows 98, CPUSPD reports 532MHz, and HWiNFO shows the same. However, CPUSPD intermittently reports 527MHz. I ran CPUSPD i in a new dosbox five more times after this screenshot and only got the 527MHz measurement one other time.
Thanks! The slight inaccuracy is expected as the frequency is measured and not calculated. The routine is in fact a text book algorithm from Intel's developer manual. It seems that the frequency settling issue is either solved with the revised code, or it's not present on Ezra.... Now I wonder is which 🤣
I'll work on your request to throttle via south bridge database once the C3 issues are settled.
