First post, by Lumpy
QuikMenu III Give DOSBox a GUI, Windows-like desktop . QuikMenu allows you to customize graphical screen interfaces and set up buttons to launch all your DOS programs.
http://www.neosoftware.com/qm.html
wrote:QuikMenu III Buys DOSBox a GUI, Windows-like desktop . QuikMenu allows you to customize graphical screen interfaces and set up buttons to launch all your DOS programs.
Fixed! 🤑
_________________
Does Dosshell works in Dosbox? I'll give a try tomorrow...
Yes it does, but of course it is easier to do any file management from the host system.
install QUIKMENUIII to your DOSBox mount c c:\ Folder.
So the "DESTINATION:" is the folde you made for your C:\drive for DOSBox.
Add to DOSBox.conf
[autoexec]
# Lines in this section will be run at startup.
mount C C:\XXXXX
c:
qm
