Reply 34920 of 56695, by gdjacobs
- l33t++
wiretap wrote on 2020-06-01, 01:55:Just won this Asus P2B-DS auction with a Make Offer deal for $119. (including RAM and CPU's) Now I can build my dually tually wi […]
Just won this Asus P2B-DS auction with a Make Offer deal for $119. (including RAM and CPU's) Now I can build my dually tually with two Upgradeware Slot-T slocket adapters. Going to load the beta BIOS, do the multiplier and voltage mods, then it should be good to go. I only have to modify one of my Upgradeware cards since it needs the 0 ohm resistor moved to enable SMP. Apparently my other is good to go from a previous owner since it is a rev 1.0 but already in the correct position.
I suggest trying NT 3.51. The amount of performance is hilarious.
