First post, by muon
Recently I've acquired a CGA card, but I don't know what model and manufacture is. The card has some jumpers and I would like to know what they are for .
Any idea?
Reply 1 of 7, by Grzyb
Not jumpers.
They are connectors for RF modulator and light-pen.
Nie tylko, jak widzicie, w tym trudność, że nie zdołacie wejść no moja górę, lecz i w tym, ze ja do was cały zejść nie mogę, gdyż schodząc, gubię po drodze to, co miałem donieść.
Reply 2 of 7, by mkarcher
muon wrote on 2020-07-05, 12:37:
Any idea?
Have a look at this documentation about the original IBM CGA card: https://www.seasip.info/VintagePC/cga.html. The original IBM card has two pin headers at a similar location. Just like your card, one of them has 4 pins, and the other of them has 6 pins. They are not meant for jumpers, but as electrical connectors. The 4-pin connector contains the composite video signal, the 6-pin connector allows to connect a light pen. The internal video output is used in the IBM PC portable to connect the internal monitor, see this video: https://youtu.be/97wcva1BEdo?t=955.
Reply 4 of 7, by Grzyb
muon wrote on 2020-07-05, 14:59:
But what about the "jumper" on the left side?
Probably selects the font - thick or thin.
Reply 6 of 7, by muon
Finally I got then name: Precise CGA....
http://www2.vgamuseum.info/index.php/componen … 469-umc-um6845r
http://21stdigitalhome.blogspot.com/2019/01/t … tery-video.html
but no info available for the card.
Reply 7 of 7, by PTherapist
I have that same card, I bought it a couple of years back from eBay. Was never able to find out the manufacturer or model info etc either, could only go by the stuff that was obvious from the chips on the card ie. UMC UM6845R.
Can honestly say I've never tried that jumper on the left hand side, so haven't got a clue on that one.
