First post, by darry
Does anybody know what the current draw distribution is for a Geforce FX 5900 (or an FX 5800) accross the 3.3v , 12v and 5v ( if used) rails when under load ? I seem to recall somebody testing that and comparing it with an ATI card back in the day, but I cannot find that reference anymore .
Reply 1 of 12, by Horun
darry wrote on 2020-05-02, 22:26:
The 5900 AGP card uses a Molex power connector (same as a IDE HD power connector) with 5 and 12v. According to www.techpowerup.com it draws a max of 59watts. If all is off the 5v rail that would be ~12amps, if off the 12v rail that would be ~5amps.
Reply 2 of 12, by darry
Horun wrote on 2020-05-03, 00:41:
Thank you. I know the card draws a max of 59 watts . I was hoping for more detailed info about power draw per rail . I found the site that I remembered from 15 years ago. Sadly, it is now offline and Internet archive does note have a legible copy of the graph I was hoping to see . I know that this not for the plain FX 5900, but it would still give an idea . Maybe someone has saved a copy .
https://web.archive.org/web/20110129051517/ht … nv-power_6.html
EDIT: Found a russian translation .
5900U :
https://st.overclockers.ru/images/lab/2004/08 … 00u_table-b.gif
5950:
https://st.overclockers.ru/images/lab/2004/08 … 50u_table-b.gif
Reply 3 of 12, by Horun
darry wrote on 2020-05-03, 02:10:
https://web.archive.org/web/20110129051517/ht … nv-power_6.html […]
5900U :
5950:
Ahh Ok my russian is not the best but looks like it closely splits the Amps draw off both 5v and 12v Molex rails, 2.5A and 3.5A plus a minimal off the AGP slot supplies. That is actually a Good thing. Most PSU made back then had good balanced 3.3v 5v and 12v rails. Would think any that had a combined 130watt+ on the 3.3/5v plus 150w on the 12v would work OK as long as you were not pushing other things like a bad-ass socket A.
Edit +added: can you find one for the GF 7800 AGP cards ? Have a BFG 7800 GS OC and always wondered what power it really takes
Reply 4 of 12, by darry
Horun wrote on 2020-05-03, 02:40:
5900U :
5950:
Ahh Ok my russian is not the best but looks like it closely splits the Amps draw off both 5v and 12v Molex rails, 2.5A and 3.5A plus a minimal off the AGP slot supplies. That is actually a Good thing. Most PSU made back then had good 5v and 12v rails. Would think any that had a combined 130watt+ would work OK as long as you were not pushing other things like a bad-ass socket A.
The card I have is an MSI FX 5900 (non ultra) with 128MB . I can only imagine its power delivery system is similar to that of the ultra .
The reason I was looking for this info is because I plan on changing PSUs from a 15-year old Enermax EG465P-VE with 35A each on 3.3v and 5v rails and 200W max combined to a new Corsair RM850x with 25A each on the 3.3v and 5v rails and 150W max combined . I do not believe I will have any issues as the FX 5900 (at load) is the heaviest power drain on the system . CPU TDP should be about 32.2 W according to Intel , Voodoo 3 should be about 15W . The rest should not be very demanding .
The machine specs are as follows :
- Pentium 3 Tualatin-S @1400MHz with 512K L2 cache
- Ipox 3ETI23 industrial motherboard (815EP-based with 3 ISA slots and onboard Fast Ethernet)
- 512 MB (2x256) of PC133 SDRAM
- MSI AGP Nvidia FX 5900 128MB
- 3Dfx Voodoo 3 3000 (PCI)
- generic SIL3114 SATA controller
- 1TB Seagate 7200RPM SATA drive (with 4 partitions, each smaller than 127GB and rest unpartionned)
- 500MB Samsung 860EVO SSD (soon)
- 5 and 1/4" floppy drive
- 3 and 1/2" floppy drive
- LG GSA-4167 DVD-ROM drive
- Gravis Ultrasound Ultralsound 3.73 with 1 MB RAM
- Creative AWE64 Value with 28MB RAM (thanks to SIMMCONN revival)
- Mediatrix Audiotrix 3DXG (OPL3SA) with Monster Midi 4MB GS rev. B daughterboard (for SB Pro compatibility and authentic embedded OPL3)
- 3 x 120MM fans
Reply 5 of 12, by Tetrium
I remember those pages! Sorry to see that the images seem to have been lost though I may have downloaded them at some point.
If I remember, I will see if I dan dig them up and upload them somewhere. I don't have good access to my backup files right now though and I have other things that need to be dealt with before.
5900U :
5950:
Iirc GF FX was mostly 5v heavy and GF6 (don't quote me on this though) and GF7 were mostly 12v.
I don't remember as well about Ati but I think the X800 was mostly 12v but not sure about Radeon 9x00 series.
It's been years since I last saw those images. I did try to google them and I did write about them earlier but at first glance I never seem to have uploaded these images to somewhere else.
I don't remember the power rails but these should be reasonably re-calculated once the total power draw and 5v/12v rail preferences are known (course better if those pics get dug up).
My retro rigs (old topic)
Report spammers here!
Reply 6 of 12, by Tetrium
Hey look at what I found! 😁
Re: I need advice for a 3DFX Config
Apparently I may have uploaded ALL of those images a couple years ago!
I'll reupload them here for everyones convenience 😀
Reply 7 of 12, by Horun
Great ! Thank you. Appears a 7800GS OC would draw about same as a 7600GT or less than a standard 7900GT but more than a 7600GS and mostly all off the 12v. Good to know.
Reply 8 of 12, by darry
If we could get permission from whoever owned Xbit Labs at the time, maybe that data could find a nice home on the vogons wiki .
Reply 9 of 12, by candle_86
darry wrote on 2020-07-10, 23:54:
Would be cool, but can you also find the firing squad and vrzone stuff
Reply 10 of 12, by Tetrium
This is what I ended up doing with the VIA C3 compatibility list which I had pulled from the VIA website before VIA removed the list from there, but I'm unsure how this would work.
Personally I think it would be fine as it would at least make the data available for the masses again, for the greater good 😜
Reply 11 of 12, by Tetrium
candle_86 wrote on 2020-07-11, 00:19:
What did these 2 produce exactly?
Reply 12 of 12, by candle_86
Tetrium wrote on 2020-07-11, 19:51:
both did alot of work with PLL's and voltage mod information, very indepth information that is sadly all gone now
