(I realized that my google doc was restricted earlier, sorry about that). […]
AlessandroB wrote on 2020-07-12, 09:07:thank you very much! looking on the internet I discovered some interesting things about hardware which is the critical part: […]
1) the CPU can be changed with a NECv20 which is faster and the clock generator can be changed by bringing the CPU to 8mhz.
2) IBM provides both the CGA card and the EGA for this computer. The latter has the possibility of being connected to the original CGA 5153 color monitor without the need to purchase an expensive 5154 EGA monitor.
3) the doubt remains on the amount of usable ram and on the effective power of the NECv20 at 8mhz together with the EGA card. Obviously all the changes are not invasive and satisfy the period-correct philosophy
The NECv20 can be a good upgrade, but it depends on the games you are trying to play. There are lots of games that will run too fast on anything other than an 8088 @4.77mhz., but it will help a little with games like Space Quest I & II and a few late XT/286 era titles.
EGA monitors are basically impossible to find, and the number of EGA games that you would want to run on an 5150 is pretty small. I would do CGA or get an 8 bit VGA card instead.
I don't think RAM will be a problem. If you have 640k or 550k or whatever you have as much as you can use on that platform anyway.
