First post, by Tempest
I'm trying to get DOS to see my 3COM Fast Etherlink XL 10/100Mb TX (3C905-TX) card, but no matter what driver I try to install I keep getting messages saying that it can't find any Bus Master cards in my system. Windows 98 seems to find the card just fine and it works there. Has anyone gotten this card to work in DOS? I suppose I could just go into Win 98 for my networking needs as all I really want to do is use Telnet to connect to BBSs and play DOOR games, but I'd like to get it working in DOS just out of principle.
--- AtariProtos.com ---
For when excellence and burnished fineries need to gently visit the warmth of your tablery
Reply 1 of 22, by _UV_
Your NIC is probably have IRQ or PORT conflict in DOS. Pause and inspect POST messages about IRQ assignments to various devices. Next either plug in another slot and see how it changes and/or disable onboard devices to free resources. Next load 3Com DOS config utility and change eprom settings for the card to something not conflicting with others.
Reply 2 of 22, by Tempest
I'm getting closer. Someone sent me what I believe is the correct driver for my card. I got the driver to see my card and install software for it.
Now I need to figure out how to set up MTCP. I can't figure out how to set up the packet driver. I need an address but I'm not sure what it is. My card has the following stats:
Device Number: 6
Bus Number: 0
I/O Port Address: 5000h to 503Fh
And the Packet Driver program says it the I/O Base is 20480 (0x5000) and the interrupt is 5 (0x5).
The config file wants a PacketInt variable, but I'm not sure what that would be. I would assume 0x5. So in my config file I have:
PACKETINT 0x5
HOSTNAME ATARIPC
that *should* work, but when I run DHCP it says:
Init: could not setup packet driver
Could not initialize TCP/IP stack
Reply 3 of 22, by aha2940
Tempest wrote on 2020-03-29, 15:04:
I'm getting closer. Someone sent me what I believe is the correct driver for my card. I got the driver to see my card and inst […]
Device Number: 6
Bus Number: 0
PACKETINT 0x5
HOSTNAME ATARIPC
Hi, maybe this will give some clue? https://www.youtube.com/watch?v=CgATAo9WVHs
Reply 4 of 22, by mbbrutman
Device Number: 6
Bus Number: 0
PACKETINT 0x5
HOSTNAME ATARIPC
I responded over at VCF but will dupe it here in case you get here first ...
PACKETINT is supposed to be the software interrupt you loaded the packet driver at, not the hardware interrupt the card is using. The PDF docs go over this. If you correct that parameter to the software interrupt you told the packet driver to use then things might start working for you.
Also check out http://www.brutman.com/Dos_Networking/dos_networking.html if you want the background on how all of this works.
Reply 5 of 22, by Tempest
Ok I think I have that part working, but running DHCP now freezes the system.
Reply 6 of 22, by jasa1063
I also cannot get MTCP to work with a 3Com 3C905-TX card and the 3C90XPD Packet Driver. It has failed on both my Pentium MMX and K6-III+ systems. I am using a static IP and there is no IRQ conflicts on either system. Running PING or SNTP usually freezes. I have to use the reset button to restart the computer. I have tired it both MS-DOS 6.22 and Windows 98 SE running only from the DOS prompt. It does work fine on another K6-III+ system running Windows 98 SE from the DOS prompt. That computer is using an Intel PRO/1000 GT card.
Reply 7 of 22, by Grzyb
If you can't get a packet driver to work, there are at least two alternatives to try:
* ODI driver + ODIPKT.COM
* NDIS driver + appropriate shim
Kiełbasa smakuje najlepiej, gdy przysmażysz ją laserem!
Reply 8 of 22, by mkarcher
Tempest wrote on 2020-03-29, 20:30:
I'm sorry to not have any better news: I did intensive research into this very problem, and the result is that the packet driver provided by 3com is a steaming pile of cr*p. The most obvious consequence are random lockups during the first transferred packets. You might get lucky with a different release of the packet driver, that would work for you by chance, but I don't know of a quality packet driver for that card yet.
Reply 9 of 22, by neoman
What I do is:
1. Running "3c90xcfg.exe RUN" - this will run the tests and somehow initializes the card so MTCP tools won't crash anymore 😳
2. Run 3c90xpd.com /r /t - this seems to disable early transfer features which helped me to get it stable
3. Then run your tool of choice (ircjr, ping etc.)
Reply 10 of 22, by rxive
I dont't know if you've figured it out, but i managed to get it working with an older version of the packet driver. The v2.0c driver works out of the box with the /r /t switches. I was using the 5.something driver and it just crashed everytime, now it works like it should and is stable.
Reply 11 of 22, by Grzyb
Strange... I also recall some problems using some 3C905 card with a packet driver, but it was back in the era...
Recently, I've tried a bunch of PCI cards in a Pentium 133 machine, with SIS chipset - and absolutely no problems with 3C905B, 3C905C, 3C905CX, mTCP FTP download speed to NUL with MTU=1500 is around 6 MBytes/s.
Obviously all the problems are dependent on a particular PCI implementation - chipset? board? BIOS?
Anyway, the only 3Com 100 Mbps card I couldn't get to work was 3CSOHO a.k.a. 3C910 - I wasn't able to find any DOS drivers... if there are any, let me know!
Reply 12 of 22, by Grzyb
I have recently tested a bunch of PCI NICs, including one 3Com:
3C900-TPO
and the results are:
3C90XPD.COM 4.0d - OK
3C90XPD.COM 5.2.6 - the driver loads, but fails to send and/or receive any packets
Never delete older versions!
Reply 13 of 22, by Grzyb
Yet another post about quality of packet drivers for 3Com's PCI stuff...
3C900-COMBO
hardware seems 100% OK - all internal tests in 3C90XCFG.EXE passed, no problems in Windows 95 OSR2
3C90XPD.COM 5.2.6:
doesn't work (time to rename it to 3C905PD.COM ?)
3C90XPD.COM 4.0d:
RJ45 port - OK
BNC port - only works when set to BNC in 3C90XCFG, when set to AUTO the packet driver hangs on "Attempting to auto detect media..."
Reply 14 of 22, by BloodyCactus
I'm running 5.2.6 on a 3c905b and 3c905C perfectly fine under dos, no issues. under a VIA MVP3 chipset.
Reply 15 of 22, by Grzyb
Yes, 5.2.6 seems OK for the 905 series, but not for 900 - therefore the "90X" in the filename looks wrong...
Reply 16 of 22, by BloodyCactus
oooh my bad 🤦🏼 I thought you were testing a 905.
hmm from memory the 3c900 and 3c905 (original) both used the Boomerang chipset and the 905B + C used Cyclone +Hurricane or Cyclone and Tornado chipsets..
I am surprised the 3c900 didnt work with the 3c90xpd.com packet driver, its essentially the same chip but I guess not close enough. I remember from my freebsd days they had a singular driver for 900/905/905b/905c as boomerang/cyclone etc were all the same.
I will note FreeBSD says the 3c900 does not have an "autoselect" you have to choose. thats probably why you get the hang with "AUTO".
Reply 17 of 22, by Grzyb
BloodyCactus wrote on 2022-08-04, 12:23:
You mean the FreeBSD driver for 3C900 lacks autoselect, right?
The hardware surely supports it - there's an option in 3C90XCFG.EXE, and it worked for me in Windows 95 OSR2.
Reply 18 of 22, by Mappy8088
rxive wrote on 2022-02-03, 13:55:
Hello, I know this is an older thread, but can someone save me from myself here. I've google-fu'd for 3 hours and I cannot find version 2.0c of the 3COM Packet Driver (3c90xpd.com ?).
I have a 3Com Etherlink 100 PCI 3C905-TX card that I'm trying to get working under mTCP in DOS. All I can find is the 3Com EtherLink PCI Bus Master Packet Driver v5.2.6, which does detect the NIC properly but DHCP hangs and it will not do anything. This sounds exactly like what's happening in this thread. The 5.2.6 driver worked fine with my previous 3C905C-TX-M card.
Can someone point me to v2.0c or any version of the packet driver that works with the 3C905-TX card?
Thank you.
