First post, by JonJonz
I have quite a few games that require DOSBOX.
They come from GOG, Steam, and other sources.
They all install a separate copy of DOXBOX, many of which are very old versions.
Is there a way to set things up so these games can run from a single up-to-date installation of DOXBOX?
Reply 1 of 3, by xcomcmdr
I'd create a symbolic link with mklink /s everywhere you want to target that single version of dosbox.exe.
Reply 2 of 3, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
xcomcmdr wrote on 2020-06-28, 14:28:
I think that is pretty much the only way to go
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 3, by junglemontana
I've taken some GOG games out of their installation directory and mounted and played them manually using DOSbox. It requires lots of manual work. Using symbolic links sounds like a good solution.
