Reply 1000 of 1402, by Horun
- l33t++
incanus wrote on 2020-07-11, 16:44:Correct, no docs for the Cirrus Logic drivers mentioned by Jonas-fr above. I recently obtained this 386 luggable and although it has paper manuals for the motherboard and peripherals, there is nothing about the CL card except for some penciled-in DIP switch settings and two 3.5” and one 5.25” floppy containing (among other things) the drivers. I will actually double-check the versions; I may have more than one. But no docs on them.
Posted your utils to the library. Could you please take a look and let me know if there is any other info I could add ?
I did create some .txt files for each .com with what little I could glean out of them.
Thanks !
http://www.vogonsdrivers.com/getfile.php?file … 1&menustate=0,0
Hate posting a reply and then have to edit it because it made no sense 😁 First computer was an IBM 3270 workstation with CGA monitor.
