First post, by johnnystarr
Hi there all. Here's the specs of my recent build:
Socket A Mobo (ASUS A7PRO)
700 MHz Athlon
256M RAM
OS: Dos 6.22
I grabbed Phil's starter pack which I've used in the past on previous builds. The EMC portion of CONFIG.SYS is this:
DEVICE=C:\DOS\HIMEM.SYS /TESTMEM:OFF
DEVICE=C:\DOS\EMM386.EXE RAM
DEVICEHIGH=C:\DRIVERS\VIDECDD.SYS /D:OPTICAL
The culprit appears to be "EMM386.EXE RAM".
Here's the odd part: I initially installed FreeDOS 1.3 on this machine while waiting on a floppy drive to come in the mail. I was able to
install it using the legacy CDROM boot etc. I'm assuming this was related to FreeDOS using 32-bit memory MGMT or something?
I'm wondering if there's a BIOS / Jumper setting I'm missing here?
FWIW, I based this build off of Phil's video: https://www.youtube.com/watch?v=K5vYD0JMD_A&t=2059s
Granted, he's using an 800MHz Duron and a different motherboard, I tried my best to follow the steps. I admit my understanding on
DOS memory is a bit lacking. Ideally, I was looking for a machine that didn't cost and arm and a leg to get up and running old DOS games. I picked
up the Cobra PCI card and have it in slot 1 even. I'm wondering if EMM386 uses a conflicting IRQ or something?
Anyway, if you guys have any idea of something obvious please let me know.
Thanks!
Reply 1 of 11, by Horun
Shouldn't you use: DEVICE=C:\DOS\EMM386.EXE NOEMS ?
You really do not want EMS unless you run specific apps that can us it (like older Word Perfect, etc)
Using DEVICE=C:\DOS\EMM386.EXE RAM with no other parameters makes all Extended ram into Expanded ram iirc.
Reply 2 of 11, by kalohimal
He is referring to Phil's starter pack, which in the EMC section is to enable EMS. I think his problem is most probably due to his PC already have something in E000, which conflict with EMM386's page frame. Try moving the it to D000 by adding FRAME=D000:
Line 2: DEVICE=C:\DOS\EMM386.EXE RAM FRAME=D000
Slow down your CPU with CPUSPD for DOS retro gaming.
Reply 3 of 11, by dr_st
Horun wrote on 2020-07-19, 17:45:
This is just a tiny list of games that I personally know that require EMS. I am sure there are quite a few more:
https://www.vogonswiki.com/index.php/List_of_ … hat_require_EMS
It doesn't change extended into expanded. It allows the memory to be used either as extended or expanded, depending on how the program wants to access it.
Reply 4 of 11, by Intel486dx33
I had that problem too with Phils starter pack. It turned out it was the wrong version of DOS files.
They were mixed versions of DOS files.
Also make sure your paths are correct.
Reply 5 of 11, by johnnystarr
@intel486dx33
That is interesting. I actually had 2 sets of DOS floppy disks, but they are both 6.22. However, when trying to install the OS my disk #2 in set 1 stopped working. The odd part is they all have the same information.
I wonder if the EMM386.EXE is somehow corrupt. Very frustrating in general. I might just go with Windows 98/SE on the machine and go with DOS 7 for certain games. I am planning on building a Socket 7 MMX @ 233MHz to leverage all the speed settings...
Regarding EMS, 2 of the games I really want to play are X-Wing and TIE-fighter. But I also have to get expanded memory working to use the PCI sound card. It requires the use of DSDMA.EXE which uses expanded memory as well.
Reply 7 of 11, by Horun
dr_st wrote on 2020-07-19, 18:43:
Ok it has me confused as EMM386.EXE RAM in MSD shows that all XMS is listed as expanded. Example on my 486 with 8mb MSD says:
Expanded (EMS) LIM version 4, total 7488k (all the free ram). If I use EMM386.EXE 2000 MSD shows only 2M of EMS instead of 7.4M with remainder free XMS.
added: so by your explaination, using the RAM switch: if an app needed extended XMS it would take it back from the EMS pool, is that correct ?
Reply 8 of 11, by Horun
johnnystarr wrote on 2020-07-19, 19:58:
Did you try EMM386.EXE RAM FRAME=D000 as kalohimal suggested ? It looks like EMM386 uses E000-Efff for the EMS page frame by default which could be part of motherboard BIOS shadow or on board NIC rom address. C000 is video so D000 is logical. Also try EMM386.EXE 8000 FRAME=D000 that would give 8Mb of EMS which should be enough for any old DOS game plus your sound card just in case DOS 6.22 EMM386 is puking because you have more than 32Mb of ram... just a thought.
Reply 9 of 11, by johnnystarr
Horun wrote on 2020-07-19, 22:06:
Yes I tried FRAME=D000 and it just hangs. I can try "8000 FRAME=D000" also though. Just to note, I have disabled all shadow memory and have no NICs installed. I have disabled all onboard features like serial, USB and parallel ports.
The sound card is a PCI YMF744 Cobra card that requires DSDMA to even run. I suppose I can remove it and try again, perhaps there's some sort of issue there? FWIW, I had no issues on FreeDOS with this card / setup. The only issue I had with FreeDOS in general was I don't think some of the games liked the FAT-32 partition. The irony is I now have 2 drives (C and D), E is Optical. The D drive is a FAT-16 MS-DOS 6.22 formatted drive with all my games. I am tempted to reinstall FreeDOS on the C drive and call it a day 😁
Reply 10 of 11, by darry
johnnystarr wrote on 2020-07-19, 23:36:
You can use FreeDOS' EMM386.EXE equivalent (JEMM386.EXE or JEMMEX.EXE ) on DOS 6.2 , AFAIK .
Reply 11 of 11, by Horun
Since you have everything non-shadowed try EMM386.EXE 8000 just to see what happens. Should only take a few minutes to edit the config.sys
darry wrote on 2020-07-19, 23:51:
Great idea !
