First post, by mt777
I want to make multiple instances of W98 in one HDD and each system will have specific settings (for quickly testing cards etc).
So I will make a fresh install of W98 + initial setup like drivers. Then clone partition to X partitions and change boot menu with proper title.
What's the best way to achieve it to avoid corruption of OS in another partitions? I prefer via USB/ATA interface.
Reply 1 of 8, by debs3759
I plan to use CF cards to achieve that. One card per setup.
Reply 2 of 8, by kalohimal
You'll probably need GRUB or similar boot loader to be able to select which partition to boot to. For cloning you could use Clonezilla running from either a CDROM or thumb drive.
Slow down your CPU with CPUSPD for DOS retro gaming.
Reply 3 of 8, by aha2940
mt777 wrote on 2020-07-18, 22:57:
What I would do is: install the first copy of windows 98 as the base. Then, clone it as many times as you need (can't exceed 4, an HDD cannot have more than 4 primary partitions and win98 does not seem to like booting from an extended partition) and finally, use some boot manager (I use masterbooter 3.7 which is open source, but there are several options) to choose which one to boot. The catch is that your boot manager software should be able to hide partitions on the fly and then boot the OS you chose. I do that for multibooting DOS, win95 and win98 on the same PC, it works perfect.
Reply 4 of 8, by bloodem
20 years ago I was using Ghost for DOS, and I still use it now. It's very reliable, never had an issue with it. It usually takes less than a minute to restore the system partition for another motherboard (I have 20+ images for multiple motherboards/chipsets).
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 5 of 8, by chinny22
Yeh back in they day we used the boot manager that came ghost for that exact reason. had 4 images for testing.
Win98 Office 2k
Win 98 Office XP
Win2k Office 2k
and yep
Win2k Office XP
Reply 6 of 8, by dr_st
chinny22 wrote on 2020-07-19, 08:14:
Yeh back in they day we used the boot manager that came ghost for that exact reason. had 4 images for testing. Win98 Office 2k W […]
Win98 Office 2k
Win 98 Office XP
Win2k Office 2k
and yep
Win2k Office XP
I hope you had matching copies of Visio 2000 and Visio 2002 for those MS Office versions. 😁
Reply 7 of 8, by chinny22
dr_st wrote on 2020-07-19, 18:46:
Nah was used for testing version compatibility for internal CRM system Office add-ins
Back in the early days when no one really knew what a CRM was so updates often broke something else 😉
Did have Visio on my laptop though 😀
Reply 8 of 8, by mt777
4 OS limit is too small quantity in one HDD (I thought about 10 instances). I tried to avoid many CF cards.
