darry wrote on 2020-07-21, 21:51:
386SX wrote on 2020-07-21, 20:32:
I've found on another known vintage computer forum a 8bit modded NE2000.COM driver I'm trying to work with my card and it seems to give me back the Mac address of the card so it should work. Considering it's the only driver I've found and I suppose the original may not work into a 8bit ISA bus with the usual PnP or not-PnP 16bit card, are there any others known common similar driver already fully tested by other users?
Thanks
I had good experiences with the chipset manufacturer provided drivers for Realtek based card. Pretty sure a packet driver was among those . Not sure about any specific issues related to use in an 8-bit slot .
What chipset does your card use ?
The one I'm using now is a Allied Telesyn AT2000B PnP card NE2000 clone I suppose.
Then a:
Kingston KNE2021LC EtherRx LC ISA 16 bit PnP
Netware Yes ISA with jumpers or PnP config 16bit too..
but all have stickers on the chips so I'm not sure the exact model of the chip itself. Do you mean probably the original driver may work in a 8bit bus too? But the NE2000 packet driver wasn't a third party driver or it came also with the original installation disks?
