First post, by marker0077
I hit save & it works, but when I relaunch DOSBox it doesn't save the changed settings. I have DOSBox 0.65, it says in the readme that it will save to the mapper.txt file & the default config does have it set to launch the file.
What am I doing wrong?
No signature
Reply 1 of 8, by MiniMax
Rank Moderator
Moderator
Where is that mapper.txt file?
Where is DOSBox looking for its mapper.txt file?
_________________
Reply 2 of 8, by eL_PuSHeR
Do you have read-only attributes set?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 8, by marker0077
@MiniMax: It's all default. The mapper.txt is in the dosbox folder & the config file just says mapper.txt, no path.
@punisher: no read only attributes.
This is a fresh out of the box set up guys. I'm new to all this so I haven't messed with it too much aside from some automounts & an added path to paths.
No signature
Reply 4 of 8, by MiniMax
Rank Moderator
Moderator
So - if you start DOSBox, with the default setup, and no mounted drives, and do a
mount C .
followed by
dir C:mapper.txt
do you then see the mapper-file?
_________________
Reply 5 of 8, by marker0077
no. I have it set to mount automatically & I don't want that removed.
dosbox.config [sdl] # fullscreen -- Start dosbox directly in fullscreen. # fulldouble -- Use double buffering in fullscreen. # f […]
dosbox.config
[sdl]
# fullresolution -- What resolution to use for fullscreen: original or fixed size (e.g. 1024x768).
# windowresolution -- Scale the window to this size IF the output device supports hardware scaling.
# output -- What to use for output: surface,overlay,opengl,openglnb,ddraw.
# autolock -- Mouse will automatically lock, if you click on the screen.
# sensitiviy -- Mouse sensitivity.
# waitonerror -- Wait before closing the console if dosbox has an error.
# priority -- Priority levels for dosbox: lowest,lower,normal,higher,highest.
# Second entry behind the comma is for when dosbox is not focused/minimized.
# mapperfile -- File used to load/save the key/event mappings from.
# usescancodes -- Avoid usage of symkeys, might not work on all operating systems.
fullscreen=false
fulldouble=false
fullresolution=original
windowresolution=original
output=surface
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
usescancodes=true
[dosbox]
# language -- Select another language file.
# memsize -- Amount of memory dosbox has in megabytes.
# machine -- The type of machine tries to emulate:hercules,cga,tandy,pcjr,vga.
# captures -- Directory where things like wave,midi,screenshot get captured.
language=
machine=vga
captures=capture
memsize=16
[render]
# frameskip -- How many frames dosbox skips before drawing one.
# aspect -- Do aspect correction, if your output method doesn't support scaling this can slow things down!.
# scaler -- Scaler used to enlarge/enhance low resolution modes.
# Supported are none,normal2x,normal3x,advmame2x,advmame3x,advinterp2x,advinterp3x,tv2x,tv3x,rgb2x,rgb3x,scan2x,scan3x.
frameskip=0
aspect=false
scaler=normal2x
[cpu]
# core -- CPU Core used in emulation: simple,normal,full,dynamic.
# cycles -- Amount of instructions dosbox tries to emulate each millisecond.
# Setting this higher than your machine can handle is bad!
# You can also let DOSBox guess the correct value by setting it to auto.
# Please note that this guessing feature is still experimental.
# cycleup -- Amount of cycles to increase/decrease with keycombo.
# cycledown Setting it lower than 100 will be a percentage.
core=normal
cycles=3000
cycleup=500
cycledown=20
[mixer]
# nosound -- Enable silent mode, sound is still emulated though.
# rate -- Mixer sample rate, setting any devices higher than this will
# probably lower their sound quality.
# blocksize -- Mixer block size, larger blocks might help sound stuttering
# but sound will also be more lagged.
# prebuffer -- How many milliseconds of data to keep on top of the blocksize.
nosound=false
rate=22050
blocksize=2048
prebuffer=10
[midi]
# mpu401 -- Type of MPU-401 to emulate: none, uart or intelligent.
# device -- Device that will receive the MIDI data from MPU-401.
# This can be default,alsa,oss,win32,coreaudio,none.
# config -- Special configuration options for the device. In Windows put
# the id of the device you want to use. See README for details.
mpu401=intelligent
device=default
config=
[sblaster]
# sbtype -- Type of sblaster to emulate:none,sb1,sb2,sbpro1,sbpro2,sb16.
# sbbase,irq,dma,hdma -- The IO/IRQ/DMA/High DMA address of the soundblaster.
# mixer -- Allow the soundblaster mixer to modify the dosbox mixer.
# oplmode -- Type of OPL emulation: auto,cms,opl2,dualopl2,opl3.
# On auto the mode is determined by sblaster type.
# All OPL modes are 'Adlib', except for CMS.
# oplrate -- Sample rate of OPL music emulation.
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
[gus]
# gus -- Enable the Gravis Ultrasound emulation.
# gusbase,irq1,irq2,dma1,dma2 -- The IO/IRQ/DMA addresses of the
# Gravis Ultrasound. (Same IRQ's and DMA's are OK.)
# gusrate -- Sample rate of Ultrasound emulation.
# ultradir -- Path to Ultrasound directory. In this directory
# there should be a MIDI directory that contains
# the patch files for GUS playback. Patch sets used
# with Timidity should work fine.
gus=true
gusrate=22050
gusbase=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:\ULTRASND
[speaker]
# pcspeaker -- Enable PC-Speaker emulation.
# pcrate -- Sample rate of the PC-Speaker sound generation.
# tandy -- Enable Tandy Sound System emulation (off,on,auto).
# For auto Tandysound emulation is present only if machine is set to tandy.
# tandyrate -- Sample rate of the Tandy 3-Voice generation.
# disney -- Enable Disney Sound Source emulation.
pcspeaker=true
pcrate=22050
tandy=auto
tandyrate=22050
disney=true
[bios]
# joysticktype -- Type of joystick to emulate: none, 2axis, 4axis,
# fcs (Thrustmaster) ,ch (CH Flightstick).
# none disables joystick emulation.
# 2axis is the default and supports two joysticks.
joysticktype=2axis
[serial]
# serial1-4 -- set type of device connected to com port.
# Can be disabled, dummy, modem, directserial.
# Additional parameters must be in the same line in the form of
# parameter:value. Parameters for all types are irq, startbps, bytesize,
# stopbits, parity (all optional).
# for directserial: realport (required).
# for modem: listenport (optional).
# Example: serial1=modem listenport:5000
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
# xms -- Enable XMS support.
# ems -- Enable EMS support.
# umb -- Enable UMB support (false,true,max).
xms=true
ems=true
umb=true
[ipx]
# ipx -- Enable ipx over UDP/IP emulation.
ipx=false
[autoexec]
# Lines in this section will be run at startup.
@echo off
mount c: "c:\gaming\dos games"
mount d: "d:\"
mount e: e:\ -t cdrom
mount f: f:\ -t cdrom
mount m: "c:\mature\gaming\dos games"
mount y: "C:\Gaming\Emulation and ROMs\DOSBox\pathadd"
mount x: "C:\Gaming\Emulation and ROMs\DOSBox\conf"
set path=z:\;y:\
That's my file. I have dosbox in the "C:\Gaming\Emulation and ROMs\DOSBox" folder, which is where the mapper.txt file resides.
No signature
Reply 6 of 8, by wd
Rank DOSBox Author
DOSBox Author
You should & do that only && to see where the file resides&
Depending on how you start dosbox, the file is not grabbed from your
C:\Gaming\Emulation and ROMs\DOSBox folder. Maybe specifying the
path to mapper.txt in dosbox.conf would work.
Reply 7 of 8, by marker0077
tried that, with & without ""s. didn't work.
No signature
Reply 8 of 8, by marker0077
alright, figured it out. for whatever reason, my "`"/"~" & "="/"+" keys do not work. When I go into the mapper I can set these keys but they are defined as "unknown", however, they do work... until I relaunch DOSBox; But, if I set any key that is known, it works fine, even after relaunch so therefore, this is a hardware problem.
Thanks for your time folks.
No signature
