First post, by Virtual
Greetings.
I've tried to browse for a solution but I didn't come across anything, so I am writing here in hope someone could shed some light on this issue. Any word of advice will be greatly appreciated.
So, here's the CPU:
When I run it on the Award Advance 10B motherboard, it displays the following in the BIOS screen:
On Windows 98:
(btw, why doesn't it display "Pentium 3" under System Properties?)
For reference, here's a screen of the motherboard's manual:
On another motherboard, it displays the CPU correctly in the BIOS:
Reply 3 of 7, by darry
For the QDI Advance 10B , the setting is in the BIOS . See page 34 of the manual .
advance_10f.pdf
588.59 KiB
30 downloads
Reply 4 of 7, by Virtual
Thank you darry and LewisRaz, you both were right.
I needed to set the jumpers to the 1-2 position first, as the 133MHz option wouldn't show on the BIOS settings by default.
Win98SE still doesn't recognize "Intel Pentium 3" under System Properties, showing instead "x86 Family 6 Model 8 Stepping 10", however SiSift Sandra now displays "Intel Celeron III 998MHz", so it's ok I guess.
Reply 5 of 7, by debs3759
If you go into device manager and delete the CPU then reboot, so Windows redetects it, that might detect it correctly as a P3
Reply 6 of 7, by darry
Is your version of Sisoft Sandra the newest that can run under Windows 98 ? My guess is that its just too old to recognize your CPU .
For CPU ID purposes, I suggest CPU-Z . There is a Windows 9x compatible version .
Reply 7 of 7, by Virtual
Ok, so I went to Device Manager a deleted a two CPU related entries, rebooted, nothing changed. One got reinstalled again after reboot: "CPU driver for AGP VIA Tech 8598" and the other:"Support for CPU" disappeared completely, hopefully it doesn't break anything.
I am running SiSoft Sandra 99, I believe this is the latest version compatible with Win98 (at least that's the only one compatible with it according to oldversion.com) afaik.
Following darry's recommendation, I've installed CPU-Z and voila:
