Voodoo 2, no image with Glide games
Reply 20 of 33, by paradigital
I would honestly just check those traces that I and NyLan pointed out as well as the capacitor I mentioned.
I’ve fixed far worse and ended up with perfectly stable and usable cards. My Voodoo 5 5500 PCI was bought faulty (missing a handful of capacitors), and my GeForce 256 DDR was bought “working” but was DOA. Turns out that was missing 11 components (resistors, inductors and capacitors), and I fixed that using reference images on VGAmuseum. The seller refunded me without wanting a return, so I ended up with a free, working GeForce 256 DDR!
If the traces don’t show continuity, then ask the seller for a refund. If he refuses (or the card was listed as “for parts or not working”) then at least you have a head start in troubleshooting.
Reply 21 of 33, by subhuman@xgtx
eeJay wrote on 2020-08-03, 16:55:
Thanks, will check. I just reviewed the seller's images (attached), and those potential damaged spots were already on the card […]
Thanks, will check.
I just reviewed the seller's images (attached), and those potential damaged spots were already on the card (both the scratch and the backs of the RAM chips).
So it isn't transport damage.
Guess I should have been more thorough ...
Edit: he claims that he tested the card with Counter-Strike (v1.3) under Windows 2000. Is that even a Glide game? Is it possible that his primary card was doing the 3d-acceleration?
try switching your monitor's cable from the top board to the bottom one.
Reply 22 of 33, by eeJay
Progress report:
I had the card checked by the local electronics guy.
- c150 was fine
- that "scratch" wasn't a scratch, continuity on the traces was fine
- the pads on the back of that RAM chip were in contact - now fixed
Now the card behaves differently - when I run a Glide game, the PC (currently an MSI 6119 with a Pentium II 350) restarts. However, it does the same thing with another working Voodoo 2.
So, I'll let you guys know in a few days when I test it with another motherboard.
Edit: Nope. Still the exact same thing - no image. Tested on a Pentium 4.
Reply 23 of 33, by mitocarrioner
I have a Voodoo2 that does the same thing, properly detected but black screen on glide. Tried with SSTV2_TEXMAP_DISSABLE=0 and glide games worked without textures.
Reply 24 of 33, by Nexxen
Isn't the capacitor, C70, on the back close to the ram chip broken/missing?
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Bare metal ist krieg.
Reply 25 of 33, by paradigital
Nexxen wrote on 2020-08-14, 11:00:
Good spot! That should indeed be present on both 8MB and 12MB cards.
Reply 26 of 33, by eeJay
Thanks for the info, guys; will replace that.
What value do I need?
Edit: checking v2 component map now ...
Edit2: not there
Reply 27 of 33, by Nexxen
As I understand the only way to know is to unsolder one of the others and measure it to find out.
You could take a very close look and see how long is the missing smd by measuring the traces left on the solder and unsolder one of the smd of the unpopulated ram chip areas, using it as a spare part (replace later).
As they should be the same for all it's a good guess to see if it works.
Reply 28 of 33, by Nexxen
Any news?
Reply 29 of 33, by eeJay
Even after putting C70 "in its place" (it wasn't missing, just not making contact with one of the pads), still no image.
The card is already on its way back to the seller.
Thanks for all you help, guys.
Br
Reply 31 of 33, by Nexxen
eeJay wrote on 2020-08-20, 13:47:
Even after putting C70 "in its place" (it wasn't missing, just not making contact with one of the pads), still no image. The ca […]
Br
Too bad, I'd have tried to replace it with a new one.
But I understand it was getting too long to solve.
Reply 32 of 33, by eeJay
@vetz: Yes, multiple times.
@Nexxen: C70 (100nf 25V) turned out to be fine.
I really couldn't think of anything else to check/try and the seller was willing to take the card back, so I sent it.
If he manages to fix it, I'd still take it.
Here is an image of the card after repairs / before sending it back.
Br
Reply 33 of 33, by Nexxen
There's a lot to check and it could also be a bad ram chip...
Well, as you say, the seller is taking it back 😀
If anything turns up keep us updated to help future voodooists.
